Z & Y trying to run in opposite directions
Discussion in 'CNC Mills/Routers' started by David Pack, Dec 2, 2023.
  1. David Pack
    Does anyone know what might be causing my x and y to run in opposite directions. I have attached a video
    Thanks.
    you mean the 2 Y's are running in opposite directions.
    the cause is that one is wired backwards, for leadscrews they must both be the same.
    this drawings shows the standard OB wire order
    docs:blackbox-4x:connect-nema23 [OpenBuilds Documentation]
    if your motors are not OB motors then the colors may differ but the intent is the same, both Y motors must be wired in the same order so they run in the same directions.
  3. Gary Caruso
    Hi David, Looks like intermittent direction changes, one of the four motors wires connection is loose
    Gary
  4. Giarc
    If you actually hooked both an X axis driver and a Y axis driver to both Y axis stepper motors, that could also be a problem. Y axis has two motors, X and Z have one each.
  5. David Pack
    Hi
    Thanks for you advise. It was a loose wire :)
