Z Probe error "exceeded travel limits" but it has not!
Discussion in 'Interfaces' started by jda70az, Jun 11, 2021.
  1. jda70az
    jda70az Well-Known
    Hi
    My machine was running fine until today. I put an 1/8th inch bit in started Probe Z axis then I get an alarm telling me the travel limit has been exceeded. Same with XYZ Probe. It moves diagonally over the probe from the cut out circle and stops before it moves along the Z Axis.
    The Travel limit has not been exceeded. It's at 90mm and works fine when jogging the machine around all 3 axis. And it was working fine yesterday. In fact it has never done this before.
    I always Home my machine after turning it on. I am using Soft Limits.
    Edit : uploaded images.
    #1 jda70az, Jun 11, 2021
  2. jda70az
    jda70az Well-Known
    Turned off the machine, then back on , home and using a 1/4 inch bit did an XYZ probe and it worked as expected.
    Changed the bit to 1/8 inch bit , home and did an XYZ probe and it worked this time.
