z-axis plunge
Discussion in 'Interfaces' started by Rusty Shackleford, Dec 28, 2021.
  1. Rusty Shackleford
    I load a program to the new interface I received a few days ago (to replace a bad one), zero out the machine, enter a program I ran last night and this morning with no issues. the z axis drives the bit straight through the part and waste board.
    What happened? I've reset everything.
    Did you remember to HOME prior to Zeroing?
  3. Rusty Shackleford
    x limit switch doesn't work now. my Goodness I hate when I can't figure something out.
    Usually wiring. Check for loose terminals, broken wires. Switch can also break if machine jams hard into it while its wiring is incorrect
