Z axis jog and home all.
Discussion in 'General Talk' started by Atif Ali, Oct 31, 2021.
  1. Atif Ali
    Atif Ali New
    i am facing a problem to jog z axis but it could not on an other side computer is displaying that z axis is moving but physically it is not moving. It is further that x and y axis is moving properly.
    2ndly i tried to home all axis it would not also work.
    Requested to all of you can you help me.
  2. Alex Chambers
  3. Atif Ali
    Atif Ali New
    Connection and current setting is correct. Power is not coming out from Black Box. I connected another motor on Z Port but motor did not move.
    But smooth hissing sound is coming from motor.
    Please tell me what to do?
    Use the FAQ page to actually measure and check your Coil wiring: docs:blackbox:faq-identify-motor-coils [OpenBuilds Documentation]. - do exactly as described. As that method properly identifies miswiring issues in both extension cables and motors. Hissing sound is classic symptom of a wiring issue as mentioned in the FAQ page, see the very first section
    Alex Chambers likes this.
  5. Atif Ali
    Atif Ali New
    Actually I have 2 no black box.
    When I connected with 2nd one its work well but with 1st one it have same issue. I think there is issue with black box. Can you help me to figure it out.
    http://support.openbuilds.com/support/home will be happy to provide further assistance
