Z axis drop when limit switch hit.
Discussion in 'CNC Mills/Routers' started by Adammdp, May 17, 2023.
  1. Adammdp
    Adammdp New
    What cases my z axis to drop about an inch when a limit switch is tripped.
    set the GRL setting 'step idle delay' to 255
    [03:42:36] [ $$ ] $1=255 ;Step idle delay, milliseconds
    this prevents the motor drivers ever going into standby, in standby they offer no resistance to turning thus allowing the drop
  3. Adammdp
    Adammdp New
    I am having an issue where the z axis plunges several inches upon a fault. I would expect the machine to stop all movement and turn off the spindle. tonight, I had a limit switch falsely trip, the machine was several inches away from the switches on all axis. After the fault, power seems to be lost from the motor and gravity is pulling the z axis down and into the material.
  4. Adammdp
    Adammdp New
    this is set to 255, the result is still the same.
    Please post a full Grbl Settings backup from the Grbl Settings tab >×Backup Grbl Settings button
