Z axis changes
Discussion in 'OpenBuilds Forum Help' started by william napier, Apr 27, 2021.
  1. william napier
    Ok tried all suggestions from FB group nothing works so far.
    Using the machine all works fine jogging and cutting . But when trying to home the z axis goes the wrong direction when I invert direction it will home as should but when I load a cut it’s backwards . I think I’ve tried every invert I. The settings to get no resolution. Any suggestions would be greatly appreciated.
  2. william napier
    Got it fixed finally found the right combination.
  3. sharmstr
    Glad you got it sorted. For the sake of someone stumbling across this post, I assume that first you set $3 so that Z move in the correct direction when jogging and cutting and then changed $23 so that it will home in the correct direction.
  4. william napier
    Honestly I tried that as it was suggested to me and I still had same issue so I went back and played with the $23 till I finally found the correct configuration lol . I’ll go back and look tomorrow to see what I did .
