X Y calibration
Discussion in 'General Talk' started by Trigg, Jan 21, 2022.
  1. Trigg
    Trigg New
    In both X & Y, they run further than what I measure. @ 20" it travels 1/16"+ past the 20". How can I re-calibrate?
  2. Alex Chambers
    What controller/control software are you using?
    The principles are in the document attached, but if you are using Openbuilds control it has a calibration wizard.
  3. Trigg
    Trigg New
    I have the black box
  4. Trigg
    Trigg New
    got it thanks alot Alex
  5. Giarc
    The longer the measurement, the more accurate you will be. Use a meter/yard stick if you have one and a really fine point V bit.
    You can point users at the video:
