Workbee 1515 cuts outside the material area
Discussion in 'General Talk' started by FlyUlixes, Feb 8, 2022.
  1. FlyUlixes
    FlyUlixes New
    Hi.
    I have a problem with Workbee.
    I set the material (board) 400x400mm in the Vcarve Pro program, I put shapes on the board. Unfortunately, after starting the project on workbee, it turned out that it cuts outside the material area.
    I would also like to add that the material was well attached to the Workbee table. I set "XYZ Operation" using the touch probe, and before that I did the whole procedure with the rest position setting for each axis.
    In the attached picture the green circles are the ones I made on the VCarve Pro, the red circles show roughly where the machine actually cut them.
    In the material settings you can see that the board has been positioned correctly.
    If it is possible, please help me.
    Greetings
    Check calibration:
  3. FlyUlixes
    FlyUlixes New
    Thanks for the quick reply. I will let you know if it helped.
