Will the Blackbox control my spindle?
Discussion in 'CNC Mills/Routers' started by galtjunk, Feb 22, 2024.
  1. galtjunk
    galtjunk New
    I have an R7 with the 800w water cooled spindle with a NowForever control box.
    I am currently using a TinyG controller.
    What do I need to be able to control spindle speed and direction with the Blackbox?
    Do I need an external board or will the Blackbox control the speed and direction?
    Is there a canned setup available for the R7?
    What is the difference between the 8 bit and the 32 bit boxes, other than the obvious bit difference?
    With only a $20 difference in price, is there some reason to buy 8 bit over 32 bit?
  2. Giarc
    The 32 bit version allows for a 4th independent axis such as a rotary axis. If building a laser, the 32bit would be better for rastering images where large amounts of data are being sent.
    Here is info regarding a spindle/VFD combo. docs:blackbox-4x:connect-vfd [OpenBuilds Documentation]
    and 32 bit docs:blackbox-x32:connect-vfd [OpenBuilds Documentation]
    Been about 14 months since the old one was in stock. Don't make them anymore
