Tramming Mount
Discussion in 'General Talk' started by Rink, Aug 23, 2022.
  1. Rink
    Rink Well-Known
    Good afternoon.
    Has anyone designed and/or manufactured and used their own "after market" spindle/router mount that provides an easier method of tramming the spindle in both axes? (both left/right and front/back).
    Thx, rink.
    The reason doesn't really exist is that adjusting the router mount fixes the angle of the router - but does nothing to correct the axis of motion (far more important)
    The now upright router still enters the material at an angle as the Z axis plunges at an angle, because (for example) the Z uprights were installed skew.
    See Tramming: A generic guideline
    Fix the problem, not the symptom :)
  3. Rink
    Rink Well-Known
    Hey, Peter, thank you.
    Yes, sir, I do understand the difference between the X/Y axes of motion vs. the alignment of the vertical axis of the router.
    Of course, first priority is to ensure the X/Y axes of motion are aligned correctly. And even if those aren’t perfect, but very close, it should be OK if you surface the spoil board to be parallel with those X and Y planes.
    But even if those planes are aligned perfectly, the vertical axis of the router could be off, correct? Either front-to-back or side-to-side?
    Your message above seems to imply that, if the X/Y axes of motion are aligned correctly, the router will automagically be aligned correctly. Did I understand? There is no slip or play in any of the screw holes or brackets that could affect the router axis independently from X/Y axes of motion?
    What am I missing? It’s something simple, isn’t it?
    Basically yes, as explained in the generic guide. The mount itself has a little left/right adjustability (but can be squared to the Z axis carriage precisely during assembly)
  5. Saddlebrooke
    It would be nice if you would put out a video on this so everyone that owns an openbuilds machine would know how to do it. It is a big problem. Every other brand has videos on this subject put out by an owner or the company that made it. Not for open builds. I have not found one yet. Please do that for us so all owners are on the same page. Thanks
  7. Christian James
    Christian James Journeyman
    I made something like in the link below but didn't clamp the pins just screwed them.
