Touch Probe Plus supported voltages
Discussion in 'General Talk' started by smaugs, Apr 5, 2024.
  1. smaugs
    smaugs New
    Hi,
    I've bought the Touch Probe Plus for a generic CNC machine. The documentation is unclear about the supported voltages for LED&Noise Filtering Circuit. See docs:xyzprobe:wiringgeneric [OpenBuilds Documentation].
    There it says that 3.3, 5 & 24V are supported - in the picture at the bottom of the page it says 5V.
    If I look at the PCB I do not see any voltage regulator or something - only a few resistors, LEDs and a capacitor - I can not imagine that this simple PCB is supporting that wide range of input voltage.
    Can someone clear things up for me?
    3.3v to 24v yes. LEDs will just be brighter on 24v
  3. smaugs
    smaugs New
    Perfect! Thank your for the fast reply!
    Just make sure your controllers input for the probe signal matches. Putting 24v power on probe but wiring it to a 3.3v controller would be bad :)
    BlackBox has safe inputs for full range, but some 3rd party ones don't
