System requirements for OB Control software...
Discussion in 'Control Software' started by Tony LaBelle, Aug 18, 2022.
  1. Tony LaBelle
    Hello All - I'm wondering what the pc requirements for running OpenBuilds Control software. Using BlackBox and Interface. Thanks! :thumbsup:
    4GB RAM, decent GPU. Rest not too important
  3. Tony LaBelle
    Hey Peter! Thanks again for the support. I'm currently using an I5 laptop to control things...issue is having all the cables coming off the sides of the laptop. Ofcoarse you have to have these cable, but I came across Mini PC's. So I was thinking of mounting a Mini PC with the BlackBox/24V Power Supply all together in a neat group. Only external cables would be for a touchscreen monitor and USB hub routed to the front of the CNC. What do you think, would a Mini PC work?!?! And any suggestions on which one to look for? Thanks again
    Post a link then we can check - the insides of those are widely varied so would need the specific details
    Of course an even cleaner solution is the Interface? No PC needed near the machine - sounds like you have the Interface already?
  5. Tony LaBelle
    Yes I have the Interface and its an awsome tool...But there's a few issues / things I don't like about the Interface, so I'm leaning towards OB Control for my 1Meter x 1Meter CNC Router build. I'll look into some of the mini PC's and post their specs for review
  6. Tony LaBelle
    Here's a model I'm interested in.
    MeLE PCG35 WiFi 6 Fanless Mini PC Computer Specs:
    Max Screen Resolution 4096x2160
    Operating System Windows11 Pro
    Processor 2 GHz Celeron
    RAM 8 GB LBDDR4
    Memory Speed 2933 MHz
    Hard Drive 128GB SSD
    Graphics Coprocessor Intel UHD Graphics
    Chipset Brand Intel
    Wireless Type 802.11ax
    Number of USB 2.0 Ports 2
    Number of USB 3.0 Ports 2
    There are many different configurations and models to choose from. Im not really interested in the 3d viewing in the Control software, it's probably the largest resource user, right? Most of the mini PC's in the price range I'm looking at use the Celeron CPU.
    Correct, and can be disabled from the Troubleshooting menu should you need to
    Celerons can be quite slow... just a heads up on that
    Doesn't say which - so can't confirm.
    If you can get it in a way that you can return it if it doesn't work for you - you can give it a try
  8. Tony LaBelle
    In quick review of the Mini PC's the price almost doubles from Celeron to I5 CPU's o_O I can't imagine the price of the I7 versions... Laptop is probably the most commonly used. The Con to that is the constant plugging/unplugging of cables and thumb drives. My current laptop's connectors getting very loose causing issues.
  9. Peter Van Der Walt
    :) Then don't :)
    Setup network shares so you don't need flashdrives. Other cables need never be unplugged
    And a USB Hub still helps too
  10. Tony LaBelle
    LOL! Very true, that's exactly what I want to do. Network shares definitly will happen. My laptop is used for other activities so it moves around quite a bit. Thanks again.
  11. Tony LaBelle
    I came across in storage a Dell Optiplex 780 Intel Core 2 Duo Desktop / 4Gb Ram would this work with OB Control software?
  12. Tony LaBelle
    I don't know what GPU it has at this point...I think its a Nvidia 1G...maybe
  13. David the swarfer
  14. Peter Van Der Walt
    If you have it there, give it a go and see :)
