source for 1500mm long 8mm Metric Acme Lead Screw
Discussion in 'General Talk' started by John Grade, Feb 17, 2020.
  1. John Grade
    Does anyone know of a US supplier where I can get a 1.5 meter long lead screw as a drop-in replacement for the one used in the openbuilds parts store?
    Yes, I know a long 8mm screw can have whipping problems. My application runs at low speeds, so that shouldn't be an issue. Backlash isn't an issue either as positioning to within 1mm is fine. Loads are minimal. I'd use a belt drive, but the client wants a lead screw.
    So far, I've found them in China, Canada, Denmark, and Germany, but shipping ends up tripling the cost.
  2. jeffmorris
    jeffmorris Journeyman
  3. John Grade
    Fantastic -- perfect -- thanks!
  4. jeffmorris
    Order 1600mm lead screws and flip the end plates around so that the bearings and collars are outside instead of inside. This should reduce lead screw whipping.
    John Grade likes this.
