So the front of the machine is actually the right side of the machine?
Discussion in 'General Talk' started by jda70az, Jan 10, 2021.
  1. jda70az
    jda70az Well-Known
    After looking at the GRBL docs and and looking at all the settings in the Open Builds software
    the max travel for a Lead 1010 X is 810 mm Y is 730mm and Z is 90mm. Well that build is longer than wider.
    Also I was told X is left to right, Y is to and from and Z is up and down.
    So what's going on here?
    #1 jda70az, Jan 10, 2021
    Joe HIgham likes this.
    Obviously an error. Thank you for pointing it out. Should be just as the Part Store description of the LEAD 1010 "X Axis 29" (730mm) / Y Axis 32" (810mm) / Z Axis 4" (~100mm)"
    You were told correctly.
    Peter will be along shortly to sort it out.
    jda70az likes this.
    Will have to validate that with the team that builds the machines, and if it is wrong, update in future version. Please log bug ticket at github.com/OpenBuilds/OpenBuilds-CONTROL/issues/new
    jda70az likes this.
  4. jda70az
    jda70az Well-Known
    Yup I'm looking at it right now X is 810 mm Y is 730mm and Z is 90mm.
    I am going to put my own numbers in there anyways so it's no big deal to me.
    Thanks for the help.
    Tes, the profiles just populate the form below for you, so go for it!
    jda70az likes this.
