Settings
Discussion in 'General Talk' started by Dean Webb, Jan 29, 2024.
  1. Dean Webb
    Dean Webb New
    Somehow when upgrading my Workbee CNC to Blackbox X32 I messed up my settings trying to home right rear instead of left front like my previous controller did. It's all fouled up now and X Y and Z won't move.
    Will factory reset allow me to start all over or should I download the software again and start from scratch.
    If I remember I inverted the x axis and disengaged 2 things but don't remember what they were or did. Obviously I'm a novice. Any advise?
    Thank you,
    Dean
    PS: will also be adding the interface and XYZ Plus but one step at a time.
    Reload last good Backup from CONTROL > Grbl Settings > Restore Backup
    Or if you forgot to take a backup when all was well (don't forget next time - backup when its working correctly!) Reload the stock profile from CONTROL > Grbl Settings > Select machine from the list > Save and Reset when prompted.
    While testing 1) Make sure it all jogs the correct way round - if not checkout $3 Direction Invert, once thats correct - then 2) fix Homing Direction in $23 according to where your switches are installed.
    Our profiles will resolve the no-movement issue (Profiles sets key values like $4-Enable Invert and also others)
