Saving zero position?
Discussion in 'General Talk' started by Todd Hoffert, Oct 15, 2021.
  1. Todd Hoffert
    Newbie question probably asked a lot here..
    Is there a way to save the machines(lead1515) zero position after powering everything down? I would think the black box would be capable of retaining that data..
    Grbl automatically does that. Just rehome on power up to re-establish all stored locations back to physical space.
  3. David the swarfer
    GRBL saves the offsets from machine home so after a home your offsets are exactly where you left them.
    It does not save '0', machine zero is set physically by homing (or faking the home), after that your offsets (work zero) come into play.
  4. Todd Hoffert
    At work so I can’t look at the software right now.. what you’re saying is I need to set the “home”position as opposed to the “zero” position if I want a repeatable xyz placement( meaning after cycling power it will remember)?
    Home first (establishes where in the real world the machine currently finds itself - ie sets Machine Zero)
    Then jog to the stock origin and ZERO using the SETZERO buttons to tell it where the Stock is (this is an offset from Machine Zero = work Zero)
    You need both, in that order, for it to persist
    Because the offset is automatically saved, once you re-home (setting up Machine coordinate system again as during power off it could have moved around) the origin (work zero) is remembered (and any other offsets, Work Coordinates G54 through G59.1, G29, G30, etc)
    See the video on docs:blackbox:hello-world [OpenBuilds Documentation] which shows you how to Home first, then setup Stock by Zeroing.
    #5 Peter Van Der Walt, Oct 15, 2021
  6. Todd Hoffert
    Will do thank you for the info!
  7. Rink
    Rink Well-Known
    Good evening.
    You guys may know this already, but…
    In the video, he says a router speed setting of 3.5 is 12k RPM. If that’s a Dewalt DWP611, I’m not sure that’s correct. I think it would be > 18k.
    I could be wrong, but I wanted to mention it.
    Thx, rink.
  8. Christian James
    Christian James Journeyman
    He may be thinking of a Makita? On a Makita, 3.5 is around 19,500.
  9. Rink
    Rink Well-Known
    Hey, Christian, good afternoon.
    Yes, you could be right. However, if the Mikita speed 3.5 = 19.5k RPM, and the Dewalt speed 3.5k = 21.5k RPM...then both of those are a long way from 12k RPM :)
    Maybe he was thinking about a spindle instead of a router?
    Thx, rink.
