Power Supply for BlackBox Motion Control
Discussion in 'General Talk' started by Nitehawkhp, Jul 14, 2019.
  1. Nitehawkhp
    I purchased the BlackBox Motion Control System during the Father's Day sale. I have completed the build and would like to test it with my existing stepper motors. However, I do not currently have a 24 volt power supply.
    I want to know if I can use a 12 volt supply just to test it. I have a 36 volt supply that I currently use to power my old CNC machine that I built more than 15 years ago. The "What is Included" indicates a 24V Cooling Fan. Is 24V the Max input for this controller?
    Thanks in advance for any help.
    19-24v is the only tested range. Probably worth waiting till you have a 24v as recommended, wouldnt want to let the magic smoke out
  3. Nitehawkhp
    Thanks for the information. With my experience, whenever the magic smoke came out, it no longer works.
  4. Guillaume Rancourt
    Hey
    Pete! :)
    Is it still true that no tests have been done with the blackbox on a 36v powersupply?
    Negative, 24v only please :)
  6. Guillaume Rancourt
    Ok!
    I'm looking into modifying a CNC a friend has, and i was about to buy another blackbox for him but i'll look into the needs for motors and see if we can manage to get enough current to drive the motors on the standard mean well 24V :)
    Thanks again for the great help, love that comunitity!
  7. peter70
    peter70 New
    Hello.
    Because i don't want to open a new thread for the same question.
    I have a WEHO power supply at 24v / 10A 250W. Because the watts are not the same 350W what limits will i have ??
    Also has anyone used this brand of power supply? Is this a good brand ?
    Thank you.
    Whats the rest of your system, what motors, what controller, etc - ie what else will be powered by the PSU?
  9. peter70
    peter70 New
    Thank you for your answer.
    My controller is a blackbox ( Today i have received it :) )
    I have 3 motors 57BYGH420P1-1. C-Beam CNC . Nothing else . The router will be powered from external psu.
    Anything else will be powered from different power supply.
    Would be adaquate then yes
    peter70 likes this.
  11. peter70
    peter70 New
    One more question. Are the motors that i told you suitable for the c_beam cnc ?? Milling pcb, wood , aluminium
  12. Peter Van Der Walt
    Do you have a complete datasheet so we can check coil resistance, inductance and coil voltage ratings?
  13. peter70
    peter70 New
    Yes of course. Thank you for your help.
  14. Peter Van Der Walt
  15. peter70
    peter70 New
  16. Peter Van Der Walt
  17. peter70
    peter70 New
    Thank you Peter, Have a nice day :)
