Only works z-axis limit
Discussion in 'General Talk' started by Rupars, Nov 12, 2023.
  1. Rupars
    Rupars New
    Hello, i started connect my limit switches to blackbox, but x and y axis not triggering then i press by hand. With z axis works perfectly. All wiring are same. All switches working fine i tested on z axis witch works. Any ideas?
    Grbl Settings backup for review and pictures of wiring please
  3. Rupars
    Rupars New
    here you go, limits switches not mounted just for testing purpose.
  4. Rupars
    Rupars New
    I can say then i push the limits switches by hand on switch itself pop red led light right up. but on software dont show then they triggered. only z-axis triggers.
    If you plug the working Z switch into X and Y respectively as a test?
    Ps on wiring, couple stripped a little far back, exposed conductors are an invite for future shorts. Snip off spare blue wire too... Double check SIG wire on non working ones, onboard LED working shows that GND and V+ is present, if SIG isn't making its way back, recheck SIG wire
  6. Rupars
    Rupars New
    Allready tested working Z on X and Y still not working. i switched working Z switch with that same wiring on to X and Y ports still nothing. i think can be openbuilds itself dead inside?
    Would be odd if it is, endstops are very simple, but sure, please do check in with the store via Support > New Ticket
  8. Rupars
    Rupars New
    yes it odd becouse its new controler. but it is what it is.
