not cutting square
Discussion in 'General Talk' started by cnctry, Mar 30, 2023.
  1. cnctry
    cnctry New
    Running plasma table with grbl 1.3 on arduino with these stepper motors -
    Y - https://www.amazon.com/gp/product/B081VD4C28/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
    X - https://www.amazon.com/gp/product/B07Y81FF3V/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
    My issue is when I cut a 4" square for example, it's about an 1/8" or more out of square (on all corners). The square cuts and all points connect , but it's like a parallelogram instead of a square (slanted square).
    I can cut straight lines that are parallel in both directions, and the correct length so it's puzzling me a bit.
    My x motor is making some humming noises (even when idle, not moving), so I'm replacing that since it's cheap enough. I tested this motor with a voltmeter and the resistance matches on both pairs of leads. Could there still be something wrong with this stepper?
    I've also swapped out the arduino and the stepper motor controllers , with exact same results.
    Thanks!
    #1 cnctry, Mar 30, 2023
  3. cnctry
    cnctry New
    Maybe, I would expect to see this issue in other cuts I've made, it seems odd to me. It seems like only perpendicular lines that should be 90 deg from each other - aren't. Seems like it wasn't doing this when I first set the machine up couple months ago. But now I'm questioning everything smh.
    I've done several 10-15" size designs with this machine that looked fine, they were art designs, not just basic squares.
  4. cnctry
    cnctry New
    adding gcode for the 4" square - anything wrong with?
    (Made in : Autodesk CAM Post Processor)
    (G-Code optimized for Grbl 1.1 / BlackBox controller)
    (OpenBuilds CNC : GRBL/BlackBox)
    (Post-Processor : OpenbuildsFusion360PostGrbl 2.cps V1.0.32)
    (Units = inch)
    (Laser UseZ = false)
    (Laser UsePierce = false)
    (Drawing name : Untitled)
    (Program Name : 4-inch-square)
    (1 Operation :)
    (1 : 2D Profile1)
    ( Work Coordinate System : G54)
    ( Tool 1: Plasma Cutter Diam = 0.0315inch)
    ( Machining time : 16 sec)
    G90 G94 G17
    G20
    (Plasma pierce height 0.0393701)
    (Plasma topHeight 0)
    (Operation 1 of 1 : 2D Profile1)
    G54
    (Plasma cutting with GRBL.)
    G0 X-2 Y-2.0591
    M3 S1000
    G4 P1.8
    G1 X-2 Y-2.0197 F60
    G2 X-2.0197 Y-2 I0 J0.0197
    G1 X-2.0197 Y2
    G2 X-2 Y2.0197 I0.0197 J0
    G1 X2 Y2.0197
    G2 X2.0197 Y2 I0 J-0.0197
    G1 X2.0197 Y-2
    G2 X2 Y-2.0197 I-0.0197 J0
    G1 X-2 Y-2.0197
    M5
    M5
    M30
  5. cnctry
    cnctry New
    resolved! thanks @Peter Van Der Walt for quick reply. 3/8" bolts were snug on the x gantry, but it had moved!
