New update- probe malfunction?
Discussion in 'General Talk' started by Michael Cramer, Dec 22, 2020.
  1. Michael Cramer
    Hey guys, just updated the control software. Went to probe just my Z axis and for some reason when my bit touches my plate, it doesn’t stop and keeps pushing down until I quickly stop it. What is going on??? Am I doing something wrong here??
  2. sharmstr
    Put the magnet on the flat of the collet nut, not the bit.
  3. Michael Cramer
    Thanks! I would’ve thought the opposite. I wonder if that’s why it was intermittently working. Sometimes it was find others it was pushing
  4. sharmstr
    That's exactly why. I've made the mistake of putting it on the round of the collet nut (dewalt) and had the same problem.
  5. Michael Cramer
    I love when things have a simple solution. Thanks!
  6. Brett Sutherland
    Something to be aware of I have recently been having problems with the probe and bit.
    Seems that there was a pine pitch buildup on the router bit (90deg V Bit) preventing a good contact
    I have taken to occasionally wiping the V bit with solvent.
  7. sharmstr
    Cleaning will also reduce heat buildup and your bits will last longer. I do it between every job.
  8. Michael Cramer
    Best recommendations for cleaning bits? Two of mine are gummed up and I tried cleaning them but it didn’t work that well.
  9. Peter Van Der Walt
    And thats why you should check the Probe by lifting the plate to touch the endmill, while checking the Troubleshooting tab sometimes :) confirm continuity before proceeding
    Christian James likes this.
  10. Michael Cramer
    that is a wonderful idea. I wish I would’ve thought of it
  11. Michael Cramer
    That was not meant to be sarcastic. It seemed really offensive the way it reads. Haha
  12. Brett Sutherland
    I have a can of alcohol (not the drinking kind) use that it will usually dissolve gum pitch quite well.
    I have large drums of pitch solvent for sanding belts but find the alcohol works just as well.
  13. John Davies
    Acetone.
    Michael Cramer likes this.
