M7/M9 support for GRBLHal on ESP32??
Discussion in 'Control Software' started by Dov Rosenberg, Aug 19, 2024.
  1. Dov Rosenberg
    I have a THC that supports anti dive functionality. While using SheetCam to add post processor rules, thate THC vendor had an example where he uses M7/M9 to turn on/off the THC to prevent diving on small cuts using a rule that activated/deactivated M7/M9 thru a specific configuration on a MACH 3 breakout board.
    I have upgraded to an ESP32S board but am not sure which pin on the processor would support this behavior. On the Arduino Uno I think it was pin 4.
    Does GRBLHal support this functionality on ESP32S?
  2. Dov Rosenberg
    Looking thru the code it looks like pin 21 would support coolant on/off correct? Does the GRBLHal support turning it high/low based on its current state/activation?
  3. David the swarfer
    not that I know of, @terjeio should know if there is a plugin for this, you may need to ask on the grblHAL project page though because tha tis where the maintainers hang out.
    grblHAL
