Long 1/4"/6.35mm Endmill Bit
Discussion in 'CNC Mills/Routers' started by Wendel Clement, May 28, 2023.
  1. Wendel Clement
    Hello,
    Is there or can anyone recommend an Endmill bit of 75mm or longer full length? I am cutting 60mm+ material which needs to go down A very deep groove.
    Thanks,
  2. Giarc
  3. Wendel Clement
  4. Wendel Clement
    I suspect that they may have gone out of business.
  5. Rick 2.0
    What are you seeing that leads you to believe this? Maybe an international internet or shipping limitation?
    They are readily available on Amazon in the US https://www.amazon.com/Kodiak-Cutting-Tools-KCT137388-Premium/dp/B007BTQ502. Amazon UK carries a far more limited collection which does not appear to include this size.
  6. Misterg
    Misterg Veteran
    #6 Misterg, May 30, 2023
  7. Giarc
    I was able to go to that link I posted, add one to my cart and proceed to the checkout. I did not follow through with a purchase though because I do not need one. It all appeared to work. But I am in the U.S.
    I did not see you are from the UK so that may not make it cost effective.
  8. Wendel Clement
    Yes indeed the site works now, it must have been down before. Thank you.
  9. Wendel Clement
    I managed to get one from their UK site BTW, thank you.
    #9 Wendel Clement, Jun 2, 2023
    Giarc likes this.
