Linear rails with c beam actuator
Discussion in 'General Talk' started by Bferster, Jul 26, 2022.
  1. Bferster
    Bferster Well-Known
    I’m interested in adding pillow block linear rails to a 1000 c beam actuator.
    I plan to place them on the outer edges of the 80mm side of the beam on each y axis.
    Then connect the x gantry via a plate that is also connected with the plate connected to the lead screw.
    Anyone done this? Any tips!
  2. Gary Caruso
    Check out the builds area, there are many examples.
    Gary
  3. Bferster
    Bferster Well-Known
    Thanks. Any ones stand out to you?
  4. Gary Caruso
    The Granit was one I can think of, very stout.
    Maybe not exactly what you are describing though.
    cheers
    Gary
  5. Bferster
    Bferster Well-Known
    Wow. That’s built like a tank. I am planning something a little more modest, with just one linear rail per side and hopefully using standard sized parts from open builds.
