Lead 1515 with Black Box drilled extra holes at start of tool path
Discussion in 'CNC Mills/Routers' started by Valin6210, May 20, 2024.
  1. Valin6210
    Valin6210 New
    At the start of a toolpath the other day the machine started at the Zero-point, moved to the plunge point and then immediately plunged too deep and through the material, moved about 1/4" and then came up to the proper height and cut the rest of the tool-path correctly.
    I've checked the GCODE and this plunge is not in the file. I also ran the tool-path twice more and it did NOT do the same errant plunge as the first run.
    Has anyone seen the controller do a random maneuver like this?
    I've attached a picture of the errant holes, at the top of the center hub. The piece is just a template for cutting other holes in the primary project, so it's not ruined but still annoying. The machine has been running flawlessly for about 2 months until this.
  3. Valin6210
    Valin6210 New
    How is zeroing different than homing? I have always just zeroed the XYZ to the material using the probe. I'm just curious why it needs to be homed and zeroed. Thanks.
    #3 Valin6210, May 21, 2024
  4. Alex Chambers
    Homing sets a reference point in the MACHINE co-ordinate system - the back, right, up corner is set to the MAXIMUM dimension for each axis and is used as a reference point for all other coordinate systems.
    Zeroing XYZ sets a reference point (in the same place on your workpiece as you set the origin in your cam software) in a Workplace Coordinate System (WCS) so your controller "knows" where in the machine's workspace you put the workpiece.
  5. Valin6210
    Valin6210 New
    Agreed, I guess I just don't see how not homing would cause the machine to plunge too deep when it wasn't in the GCODE. Also to do it randomly (1 out of 3 runs).
  6. David the swarfer
    some Gcode moves are relative to home, that is why homing is important, as explained in the 2 links I gave you
    Alex Chambers likes this.
  7. Valin6210
    Valin6210 New
    Understood. Though from doing some reading it seems all GCODE commands are executed from the ZERO point. Here is the snippet of GCODE where it plunged too deeply, there doesn't seem to be anything that implies one command is from HOME vs ZERO (I'm not trying to be difficult; just trying to understand the process):
    G0X6.0000Y6.8162
    G0Z1.0000
    G0Z0.2000
    G1Z0.0000F10.0
    This is where it plunged too deeply
    G1X6.0802Y6.8123Z-0.0038
  8. David the swarfer
    G53 commands operate with reference to home
    and add to that
    my apologies, I missed the randomness of it.
    random movements imply EMI or other communications failure, ie what the PC sent is not what the controller received.
    EMI docs:blackbox-x32:faq-emi [OpenBuilds Documentation]
    communications docs:blackbox-x32:faq-usb-connection-failed [OpenBuilds Documentation]
  9. Valin6210
    Valin6210 New
    #9 Valin6210, May 21, 2024
  10. Christian James
    Christian James Journeyman
    Hi Valin6210
    When you had that end-mill plow right through the workpiece, did you press "return to zero" by any chance? (The question is only relevant however if you zeroed off the spoil board.)
  11. Peter Van Der Walt
    PC vs Interface, same thing. In that context above EMI is EMI. Same corruption of electrical signals regardless where they originated.
    However EMI tends to be more random. Won't always be Z and only at the start of the job. Those symptoms makes it feel more like something in your zeroing procedure or something similar.
  12. Valin6210
    Valin6210 New
    Not that I'm aware of. I always zero using the probe plate to the material (left, front, top of the material).
