Lead 1515 to Plasma Cutter?
Discussion in 'General Talk' started by Sonicboom, Feb 27, 2023.
  1. Sonicboom
    Sonicboom New
    So i have had a lead 1515 for a few years now as well as some 3D printers and i was wondering if it's possible to convert the 1515 to a plasma cutter. I figured i could use the printers to make at least a few if any of the 3D printed mount/brackets if needed.
    I did opt for the high torque steppers if that makes a difference.
    If there is a build on here someone has already done, that would be great as well.
    TIA
    Checkout (video uses the 1010 but same concept applies)
    And make sure to get the correct Inverter
  3. Sonicboom
    Sonicboom New
    Thank you!, That's exactly what I was looking for.
