Is there an E-Stop diagram/howto for the Black Box control?
Discussion in 'OpenBuilds Forum Help' started by Webweave, Jul 22, 2022.
  1. Webweave
    Webweave New
    I'm done using the mouse as an e-stop.
    Anyone out there can point me to an official doc or a good how to? Thanks!
  3. sharmstr
    And if you're just looking to stop the machine without using the mouse, you can use the ESC key keyboard shortcut. More shortcuts listed in Wizards and Tools -> Customize Keyboard Shortcuts.
  4. Webweave
    Webweave New
    What about the "DOOR" contacts on the Black Box Control?
    That's for hooking up a door switch for the enclosure: See docs:blackbox:connect-door-sensor [OpenBuilds Documentation]
    What do you need. The E in E-stop means Emergency. Do you want to rely on a firmware based input while an endmill is chopping off your fingers? Or would you prefer to cut all power?
    If you want a button for "oh no I forgot to zero" that's the Abort button in Control which you can easily hit the ESC key on your keyboard for.
    #5 Peter Van Der Walt, Jul 23, 2022
  6. Webweave
    Webweave New
    OK, I get it. My machine is small and intentionally weak and I cut nothing harder than wood so shutting off the power seems to be a bit of an over reaction. My problem is I keep snapping off bits. After homing I'm always hitting a clamp or fixture and would like some kind of large button that just does a halt.
    I was looking for documentation on the "DOOR" contacts on the Black Box. That might be closer to what I want.
    Thanks so much for hearing me out. I really love using this machine, it is making my dreams come true. I'm putting in the hours and seeing the results, I couldn't be more pleased with how far I've come.
  7. Webweave
    Webweave New
    Oh that's good. Thank you!
  8. Webweave
    Webweave New
    Thank you so much Peter, I got my "Escape Button/Door Switch" working.
  9. Peter Van Der Walt
    Just reiterating in case anyone else stumbles on this - be warned that this approach does not provide any margin of safety against any accident. DOOR is just a firmware pause!
