Interface display - white lines across screen
Discussion in 'Interfaces' started by Russell Huband, Mar 3, 2023.
  1. Russell Huband
    Hello,
    My interface display has white lines across the screen that do not change or move when the interface is reset or menu's accessed.
    Has anyone seen anything like this? I've found a replacement display with matching spec's but before I go and swap it out, I thought I'd ask the question here - I don't want to replace the display and find that there is a problem elsewhere.
    The interface works fine otherwise. Thank you.
    Looks like physical damage, if you are up for a swop, a successful replacement should fix it.
  3. Russell Huband
    Thanks Peter, I half-way came to this conclusion last night after a quick desolder - resolder of the current display. A replacement is en route.
  4. Russell Huband
    Replaced the display and the lines are gone. The display I ordered was a "3.2 inch SPI Serial color without touch LCD screen TFT ILI9341 driver" and it was a perfect swap.
    Initially I tried a 2.8 inch, but it was not the right size.
    2.8 on the left, original in the middle, new 3.2 on the right:
