How to use Fusion 360 to create 3D craving?
Discussion in 'CAD' started by jeffmorris, Mar 5, 2022.
  1. jeffmorris
    jeffmorris Journeyman
    How can I use Fusion 360 to create 3D craving for CNC router? I used to create 2D drawings in AutoCAD, save the drawings, import drawing into VCrave Pro 10.5, create toolpaths, and run jobs. I don't have the money for AutoCAD and AutoCAD compatible software have problems with saving files that can be loaded into VCrave Pro.
  2. Giarc
    You can save your Fusion 360 model as a .stl file and import that into Vcarve. That is what I do. For example, I wanted to carve a mason bee into the sides of some mason bee houses I have been making. I found an image online, I traced it in Fusion 360 and extruded it onto a round concave drawing. I saved it as an .stl and now I can import it into a Vcarve project's work stock piece and scale it however large I want it. Then create the tool paths.
    #2 Giarc, Mar 5, 2022
  3. Giarc
    If you just want to transfer 2D drawings, save them as a .dxf file.
  4. David the swarfer
    or just use Fusion360 for everything, from drawing to CAM
  5. David the swarfer
    and this
