How to create g code in openbuilds cam without z axis
Discussion in 'General Talk' started by Mob1810, Jan 28, 2021.
  1. Mob1810
    Mob1810 New
    Seems like a straight forward answer however I just can’t seem to work out how to generate the gcode to work due to the z axis keeps moving and comes up with an error.
    I want the gcode to work like the hello world sample file I uploaded.
    laser working and enabled just problem with the z axis. How to disable the z axis in openbuilds cam? Also keep the laser powering on for engraving and off for the movement.
    Does anyone know?
    Thanks in advance
    Enable Laser Mode gnea/grbl
    Flash the 2 Axes firmware from CONTROL (If you select Acro, it asks you do to so, or you can manually do so from Wizards and Tools > Firmware Flashing tool menu.
    From a CAM perspective, if you don't have a Z axis, the moves will just be ignored, so they can be present too, doesn't matter. Though settings Z Clearance height and other Z values to 0.1mm for example avoids waiting for the nonexistent axis to move
  3. Mob1810
    Mob1810 New
    Thank you. It’s working
    #3 Mob1810, Jan 28, 2021
