How to connect my Laser Rotary with a switch?
Discussion in 'Laser Cutters' started by BTopper, Jan 9, 2023.
  1. BTopper
    BTopper New
    I built my own rotary with a nema 17. Can someone please show me how to wire it so I can flip a switch from normal to the rotary? I've got a switch and a seperate controller for it.
  2. BTopper
    BTopper New
    Using a ruida controller
  3. David the swarfer
    pretty big switch but it will work.
    what you need to do is switch between 'normal' (is that X or Y?) to rotary, switching only the 'step' signal wire.
    rotary controller step in --------# # # --------------------- X/Y step in
    controlboard step out ----------------|
    The '# # #' are 3 pins of the switch, the center one being the common pin, and the 2 outside ones being switched on in turn by the switch being one side or the other.
