Grub screw replacement on Y axis belt drive 1510
Discussion in 'General Talk' started by David Marchant, Aug 20, 2022.
  1. David Marchant
    Sooo.. i replaced X axis set screws .. tightened right up.. my question is.. what is the best process to change Y axis set screws on a belt driven 1510?
    Reason is i feel like i have the same issue on Y as i had on X .. stuttering.. missing steps .. When X was a mess.. i had issues with consistency and returning to work zero after size check .. calibration came out a lot better after changing X axis grubs.. hoping for same result after changing/tightening Y axis grubs.. IMG_20220820_181601500.jpg
