GRBL: am I using the wrong edge of the control signal?
Discussion in 'Controller Boards' started by Tibia, Dec 7, 2022.
  1. Tibia
    Tibia New
    Hello,
    I have a stepper driver TB6600 connected to an Arduino GRBL axe. It works, the stepper turns, in the right direction, the right amount. Even Universal Gcode Sender is happy :)
    I have a doubt: the stepper board has only "negative" input pins, ENA-,DIR-,PUL-, like in the picture below. I believe that means "Active Low".
    I assume GRBL activates Arduino pins positive, via a rising edge "Active High".
    So here is the question: am I actually using the controller inverted? I mean, is the controller is activated when the Arduino pin pulse is returning down , on its falling edge ? Things would still work but -as a minimum- the length of the pulses is very wrong ...
    I hope I managed to explain myself. Thanks in advance to anyone that can clarify this to me .
    Tiberio
    #1 Tibia, Dec 7, 2022
  2. Christian James
    Christian James Journeyman
    Not familiar with an Arduino Axe, but those pins connect to an Arduino Uno as follows:
    Dir uses digital pins 5, 6, and 7 on the Uno
    Pul uses digital pins 2,3, and 4 on the Uno
    Ena not used
    +5v to +5v on Uno
  3. David the swarfer
    Tibia likes this.
  4. Tibia
    Tibia New
    Thank you David, that's what I was looking for !
