Generate g-code send to openbuilds control
Discussion in 'General Talk' started by Douglas Stewart, Apr 21, 2024.
  1. Douglas Stewart
    Looking for some advice just recently started using openbuilds controller ( 2 weeks ago) everything was fine until today. Can generate g-codes but missing the part where you send it to openbuilds control. Hopefully its just one of my moments but can't get it. Your help is very much appreciated.
    Your screen resolution a bit low - guessing 1366x768, might have to drag toolpath and documents sections smaller (vertically ) to show all 4 steps
  3. Douglas Stewart
    Thank you Peter will do that tomorrow.
    Compressed the elements a little to account for the small screen resolution. Ctrl+F5 to refresh the page and it should fit a little better on small screens now
    You should see the 4th step then
  5. Douglas Stewart
    Perfect Peter will do that when im home from work thanks again for the help and support
  6. Douglas Stewart
    Thank you Peter follow your advice cheers
