G-code to cartesian co-ordinate
Discussion in 'General Talk' started by SamFlynn, Nov 22, 2019.
  1. SamFlynn
    SamFlynn New
    Hey guys,
    Hope you all are doing well.
    Firstly forgive me if this is not he place to post this.I am a somewhat new to this cnc thing and probably answers already posted elsewhere ,but i fell so lost.
    So I built a 5 bar linkage mechanism using arduino and python.It uses 2 servos, an arduino mega, a 12v power supply,a dc-dc step down converter to power everything.
    The arduino's job is to to take two angle input in a csv format via usb serial input and rotate the servos to that specific angle.
    The python script's job is to take a xy input in csv format via terminal and calculate the two angles using inverse kinematics so that the end-effector reaches the desired xy position and send them to the arduino via serial.
    I have been seeing a lot of pen plotter videos recently and saw almost all of them use grbl and universal g code sender.
    What i want to do - use g codes to with my python script to plot figures.(I dont care about accuracy,i just want to see some plots :]).
    So is there any scripts or something related which takes G-codes as input and outputs XYZ position of the toolpath in correect sequences so that
    I can just input those sequences in my python code to get the plots hopefully?
