G code editor and sim mode
Discussion in 'General Talk' started by Les Adams, May 12, 2023.
  1. Les Adams
    Les Adams New
    Is it possible to run the G code list and the sim mode at the same time?
    probably, have you tried?
  3. Les Adams
    Les Adams New
    Yes Ive tried but if you open sim and then oped editor it closes sim
    Sim keeps running when you switch tabs. It only stops when stopped using the stop button, or if the sim is finished (reached end of the gcode)
    What does change is if you had it zoomed or rotated, view is reset when you click the 3D view tab (way to reset the view too)
  5. Les Adams
    Les Adams New
    I guess what im asking is can you view the sim and the Gcode running at the same time. THe sim runs but if I hit G code ed. the sim disappears. Id like to see the sim and Gcoe progression at the same time Thanks,Les
    No, not at this time.
  7. Les Adams
    Les Adams New
    Thanks . Would be a great feature to track lines to edit in long complicated runs. No doubt well within your advanced skill level. Thanks for the reply, Les
