Floating head limit switch set up
Discussion in 'General Talk' started by Mc Fab, Apr 18, 2022.
  1. Mc Fab
    Mc Fab New
    Hey guy I’m have trouble with my z axis with my floating head. I’m able to “home all” my limit switches just fine, even the z axis to touch the material and raise up as it should. Once you start a job it raises up all the way or will go down until it hits my limit switch (hard stop) Any ideas on how to reset this? I’m hoping after this is set I can make a first cut!
  3. Mc Fab
    Mc Fab New
    g code
    That's the Workspace :) not the GCODE
  5. Mc Fab
    Mc Fab New
    ; GCODE Generated by cam.openbuilds.com on 2022-04-18
    G21 ; mm-mode
    G54; Work Coordinates
    G21; mm-mode
    G90; Absolute Positioning
    ; Operation 0: Plasma: Vector (path outside)
    ; Plasma Kerf: 1.2
    G0 Z3; move to z-safe height
    G0 F1000 X85.4986 Y17.9964
    G38.2 Z-30 F100; Probe
    G10 L20 Z0; Set Z Zero
    G0 Z1.5; Move to Pierce Height
    M3S1000; Tool On
    G4 P0.5; Pierce Delay
    G1 F700 Z1.5000
    G1 F1000 X85.4986 Y19.3964 Z1.5000 S1000
    G1 F1000 X35.4986 Y19.3964 Z1.5000 S1000
    G1 F1000 X35.1926 Y19.4803 Z1.5000 S1000
    G1 F1000 X34.9773 Y19.6994 Z1.5000 S1000
    G1 F1000 X34.8986 Y19.9964 Z1.5000 S1000
    G1 F1000 X34.8986 Y69.9964 Z1.5000 S1000
    G1 F1000 X34.9825 Y70.3024 Z1.5000 S1000
    G1 F1000 X35.2016 Y70.5177 Z1.5000 S1000
    G1 F1000 X35.4986 Y70.5964 Z1.5000 S1000
    G1 F1000 X85.4986 Y70.5964 Z1.5000 S1000
    G1 F1000 X85.8046 Y70.5125 Z1.5000 S1000
    G1 F1000 X86.0199 Y70.2934 Z1.5000 S1000
    G1 F1000 X86.0986 Y69.9964 Z1.5000 S1000
    G1 F1000 X86.0986 Y19.9964 Z1.5000 S1000
    G1 F1000 X86.0147 Y19.6904 Z1.5000 S1000
    G1 F1000 X85.7956 Y19.4751 Z1.5000 S1000
    M5; Tool Off
    ; retracting back to z-safe
    G0 Z3
    Did you remember to SETZERO the stock intially?
  7. Mc Fab
    Mc Fab New
    is this what you're referring to?
    Jog into position, Zero out the DROs using the SetZero buttons so the machine knows where the stock is
  9. Mc Fab
    Mc Fab New
    I’m sorry what is the DRO?
    Do you set the
    xy- above the work
    Z- to touch/ just about to touch metal
    Then probe test and then home the limits?
    Home first
    Zero XY
    Zero Z too at least within the distance you allowed probing (if you allow - 30mm in your G38.2 it will only search down 30mm before giving up)
    Probe as part of the job
    Dro = digital read outs
  11. Mc Fab
    Mc Fab New
    Ok so I’m the application setting
    Plasma: Touch off sequence
    G38.2 (Z30 this is the 30mm drop detection?) or
    G38.2 Z-30 F100;Probe
    G10 L20 Z0; Set Z (Zero) change this to the drop detection sequence
  12. Peter Van Der Walt
    Starts at where you last zeroed + the Z move above it. Then moves down a max of 30mm
    Sets Zero where the probe stopped
    Thats not what I refer to when I ask:
    You, as operators sets the stock zero initially (front, left corner, just above the surface)
