Chain drive for the Y-Axis
Discussion in 'CNC Mills/Routers' started by ricklach, Sep 9, 2020.
  1. ricklach
    ricklach Well-Known
    Has anyone tried a chain drive for the y-axis and if so what are your opinions (versus 2 NEMA step drives)?
  2. Kevon Ritter
    Kevon Ritter Veteran
    Chains are meant to operate in one direction which makes them a horrible option for anything precision. I'm assuming that you are talking about linking two separate lead/ball screws. If so, you can use a belt, but you need to make sure it's a heavy enough duty belt to avoid stretch and/or slip for your application.
