cam issue
Discussion in 'CAM' started by bo Toepfer, Aug 13, 2020.
  1. bo Toepfer
    Yesterday I designed a 3.5" x 1" circle to test the accuracy of the design, I cam'd it as before and used the XYZ probe, when I went to cut the job the bit went to the starting point and the Z axis went to the Pos, ( up) hitting the limit switch, when I used the simulate before cutting it functioned as cm'd,, what now,, I had just installed the link for the post processor for Fusion 360 following from the Doc. file on the O B site, Thanks
    The fusion post does a G53 Z move (Machine coordinates)
    To use it you need limits installed and working correctly, machine homing working as per the cartesian standard (Z0 homes to top of the z axis)
    That G53 moves is the "z safe" move but in Machine coordinates
  3. bo Toepfer
    the machine homes so let me look into how to set the limits,,might there be a tutorial?
  4. bo Toepfer
    ok i will thanks
  5. David the swarfer
    a - you need to make sure that your retract height is not too high
    b - you probably need to put in a negative number for the Z retract in the post to prevent hitting the limit switch
