built an indexable camera mount
Discussion in 'General Talk' started by John Ger, Aug 1, 2024.
  1. John Ger
    John Ger New
    I think I want to try one of the lightburn cameras maybe a beagle one. But I have 2 different machines side-by-side. So I thought I would build a mount to move it between the 2. I had a spare stepper some left over hardware from 14 and 35 yr. old material. I have a couple spar MakerBlock Orions, which are ardruino programmed.
    I figured out what all materials I had for the actual movement rig. I decided to try using a rod and sleeve design with a looped belt. I spliced 2 belts together, I had to attach 2 rods together with a long screw that i cut the head off of. I had some different brackets and just figured it out. I had a left over support arm from a Travel trailer awning that we scrapped 35 yrs ago LOL.
    IMG_26601920×1440 370 KB
    I wanted it so hang the camera from above and be able to be stopped by 2 limit switches or even timed by the steps to stop in exactly the same spot every time.
    IMG_26631920×1440 197 KB
    IMG_26651920×2560 384 KB
    I wanted a simple 2 button control, so I folded up an aluminum one I made on the box brake.
    IMG_26671920×2560 288 KB
    Using the old controller was hard, with the brain issues I can not remember a lot of it and some of it I cant seem to understand. So I came up with this using a block system that had some limitations. It runs off the buttons and stops at the limit switches but I cant hit a button and it run again unless I power it off and on.
    Screenshot 2024-08-01 150758955×548 55.5 KB
    IMG_26661920×2560 459 KB
    Not to bad and works pretty well. I will adjust height and travel limits when I get the final camera as well as cord managment.
    If any one knows what i need to do to stop the having to restart it after it stops on a limit switch i would appreciate it.
    Mark Carew and David the swarfer like this.
  2. John Ger
    John Ger New
    I made a case for the controller, added an external power supply plug. I made the case where the input/output boards would mount on the sides. the orion isnt great for saving space 027129c730a94d699f71bcbc2c1f0cccdefe474e.jpeg b1d97103bbb5730921d749ccc4a4f8ead2da1bc1_2_375x500.jpeg bbf4aa4f26de2cb3e4d392f1f0a7db23e03f0909_2_666x500.jpeg cf73f7293583bde7b3dded928fcbf6c8090cfc08_2_375x500.jpeg dc4899f0b871a364b61793a3e1e59be4bb3674dc_2_375x500.jpeg 6b0b50f8fa183797b9614f778ab351e2348177f8_2_375x500.jpeg 6dbd7fe73750489ec970961702414f808c6ad1f8_2_375x500.jpeg 41a62935d5a5afc1cf4cb4193cb0665858cf8f4c_2_375x500.jpeg 027129c730a94d699f71bcbc2c1f0cccdefe474e.jpeg b1d97103bbb5730921d749ccc4a4f8ead2da1bc1_2_375x500.jpeg bbf4aa4f26de2cb3e4d392f1f0a7db23e03f0909_2_666x500.jpeg cf73f7293583bde7b3dded928fcbf6c8090cfc08_2_375x500.jpeg dc4899f0b871a364b61793a3e1e59be4bb3674dc_2_375x500.jpeg 6b0b50f8fa183797b9614f778ab351e2348177f8_2_375x500.jpeg 6dbd7fe73750489ec970961702414f808c6ad1f8_2_375x500.jpeg 41a62935d5a5afc1cf4cb4193cb0665858cf8f4c_2_375x500.jpeg
