I have recently bought an x32 and everything works fine except it doesn't turn on my motors. When I give the command to jog it says it is doing something but nothing happens. If anyone knows what is going on or has anything for me to try please let me know, Thank you.
Did you remember to load a machine profile? CONTROL > Grbl Settings tab > Select a machine from the list. Save and reset when prompted Profiles sets key values like $4=0 to enable motors, $5,6,10 and others too
With the LED indicator indicating they are enabled, the only other reason then would be power (does the fan inside BlackBox spin?) or motor wiring a
If the fan isnt spinning you arent providing 24v power. Check PSU, check PSU wiring, Check all switches (115/230v, PSU switch, BlackBox Switch, Wall socket) docs:blackbox-x32:connect-psu [OpenBuilds Documentation]
