Blackbox x32 disconnect from pc
Discussion in 'General Talk' started by Sasha1102, Apr 7, 2023.
  1. Sasha1102
    Sasha1102 New
    Hi everyone, I’m building a cnc plasma using a Blackbox x32. I had lots of problem with interference but now using shieldied cable I’m able to start the machine. Now the only problem is that the machine start, does 1 or 2 cuts but then, the pc loses connection with the blackbox. I don’t know if this is cuased by the hf of the plasma or if it is a problem of the blackbox.
    Can anyone give me some advice ?
    Thank you
    Is your inverter a CNC suitable (LF or Blowback start) and not perhaps a HF inverter?
    HFs are for hand cutting. For CNC you really want a LF/Blowback
    Cheap options exists these days
  3. Sasha1102
    Sasha1102 New
    Do you have any plasma LF/Blowback to recommend that it’s available in Europe/Italy?
    Check local sellers, cut50l is available even here in rural part of South Africa where I am
    Hynade also makes a cheap one. Several vendors has them these days (HF is 1980s tech)
