Blackbox GRBL Setting for Z Axis
Discussion in 'CNC Mills/Routers' started by KCollins, Jul 4, 2023.
  1. KCollins
    KCollins Well-Known
    I am getting a "Homing Fail. Could not find limit switch within search distance." See attached image. Where in the GRBL settings do I adjust that search limit so the Z Axis will not time out before it homes.
    Max Travel. See the Grbl Wiki to learn more
  3. David the swarfer
    you can also 'park' the machien near home before you turn off so it does not have so far to go to find home.
    Grbl v1.1 Configuration
