Black Box X32 print from SD
Discussion in 'General Talk' started by Gizmo6, Mar 28, 2023.
  1. Gizmo6
    Gizmo6 New
    Can the Black Box print G code from the SD card without having a computer attached?
    I don't have a computer in the shop and would like to avoid having to relocate the Acro or my computer every time I need to cut something.
    The blackbox X32 can do it provided you have set up the Wifi credentials (in CONTROL).
    once it is on your wifi you can connect to it with a browser and use the web page to upload files and start the cut.
  3. Gizmo6
    Gizmo6 New
    Thank you, I will look up the procedure and use the Wifi.
