Best Anti-Backlash nuts/blocks for 8mm Lead Screws?
Discussion in 'CNC Mills/Routers' started by dJOS_500, Jan 10, 2024.
  1. dJOS_500
    dJOS_500 Journeyman
    Hi All, Im in the middle of yet another upgrade to my CNC Router, and I was wondering what are the best type of Anti-Backlash nuts or blocks for 8mm Lead Screws?
    I've come across 3 main types:
    3D Printer Style:
    Nylon / Delrin Nut Block:
    Type 2 Style?:
    Even tho my machine is quite small (300x300mm work area), I do have some strong (for Nema 17's) 2.5A rated motors by LDO (42STH48-2504AH) driving the X/Y lead screws and Im hoping to chose a durable, but effective anti-backlash setup.
    Thoughts?
    #1 dJOS_500, Jan 10, 2024
    We’ll as 1 and 3 won’t work with a CNC router, by default number 2 wins. Routers push back as they move through the workpiece which would compress the springs in 1 and 3, causing error. 3D printers have no push back which is why they work with printers.
    dJOS_500 likes this.
  3. dJOS_500
    dJOS_500 Journeyman
    Cheers, I suspected that was the case and have just spent the last few mins designing some mounting blocks to replace the spring types that came with my machine.
    Btw, how durable are the Delrin AB blocks?
    #3 dJOS_500, Jan 10, 2024
  4. Rick 2.0
    Suitably durable for a hobby grade machine.
    Please let us know how it works out :thumbsup:
  5. dJOS_500
    dJOS_500 Journeyman
    Cheers, I will.
  6. dJOS_500
    dJOS_500 Journeyman
    Install went smoothly, although I am yet to reinstall my lead screws and stepper motors as Im waiting on some longer stepper motor mounting bolts to arrive.
    I did partially insert my lead screws to confirm everything aligned properly, and thankfully it all looked good.
    Semper Why likes this.
  7. dJOS_500
    dJOS_500 Journeyman
    These AB Blocks seem to be working really well so far.
