Beginner question regarding toolpath / tool selection
Discussion in 'General Talk' started by Robert Drisaldi, Jan 1, 2021.
  1. Robert Drisaldi
    Happy new year everyone!
    I'm working through the V-Carve pro learning curve. So far so good, thanks to the help and advice from all. I've run into a toolpath strategy obstacle and I'm sure it's a simple fix, but I'm stuck. Attached is the .crv file for a simple tool tray that I'm trying to cut. I can't figure out which toolpath strategy or type of tool to use for the text / numbers part of the job.
    Thanks in advance for taking a look!
    Robert
  2. Christian James
    Christian James Journeyman
    As far as I know, only those folk who have your version (or later) of V-carve will be able to open your file.
    #2 Christian James, Jan 1, 2021
  3. Alex Chambers
    It's late here in the UK, but I'll try to have a look tomorrow if no-one else chips in, but an important question is what do you want the text to look like? - using a V-bit to engrave it is one option, raised? flat bottomed pocket? (I haven't looked at your file yet - there may be clues in it) Any hints would be useful.
  4. Alex Chambers
    Had a quick look before bed. The text has lots of open vectors - rather than trying to find them all I used the quick engrave toolpath, 60 degree V-bit and 1mm depth - revised file attached here.
    Robert-Lee likes this.
  5. Robert-Lee
    Thanks Alex. I did figure out the open vector scenario because I kept getting the open vector message when trying to calculate the tool path. Didn’t think about using a v-bit. I was using a
  6. Robert-Lee
    Continued.....
    A ball nose bit, which was why I was getting a crappy result. Thanks for the info.
  7. Alex Chambers
    I should have said - I converted the text to curves when I was thinking about fixing the open vectors.
