Arduino Uno rev3 + Wifi with CONTROL Software
Discussion in 'General Talk' started by Dov Rosenberg, Feb 8, 2024.
  1. Dov Rosenberg
    After I blew up my BlackBox 32x, I decided to go with a custom Arduino build instead. I have an Arduino Uno Rev 3 that I was able to flash with the GRBL 1.1 and connect to the CONTROL software using the USB port (on my Mac that I struggled with on the BlackBox). My question is - has any one added a WIFI module to their Arduino so they can upload GCODE files to CONTROL remotely? I am pretty new to Arduino - I found this module that seems like it would work - Wifi Esp Click. My question is what would I need to do to send a file to CONTROL via WIFI?
    Thanks in advance
  2. JustinTime
    JustinTime Veteran
    CONTROL is on you MAC! Having a WiFi module on the Arduino will not help getting the file to CONTROL You have to get the file to your MAC.
  3. Dov Rosenberg
    Trying to get the files from my Mac to the Arduino without having to have a USB cable connected. Also considering Bluetooth as an option
  4. JustinTime
    JustinTime Veteran
    That, I think, will require a special version of GRBL that I don't think exist.
  5. David the swarfer
    what you need is an Interface, that will allow both direct control and wifi control of your machine
    INTERFACE CNC Touch
