Using a solenoid on an arduino cnc shield and gcode
Discussion in 'DrawBot' started by seanenroute, Aug 22, 2017.
  1. seanenroute
    Hi, I've been tinkering with a cnc pen plotter. I'm able to run a servo for the z axis but would like to switch it out with a small solenoid. Does anyone have an idea on how to wire it to the cnc shield and then control it with gcode?
  2. David the swarfer
    wire it to the Coolant Enable pin and control it with
    M8 to turn it on (equiv to Z down)
    M9 to turn it off (equiv to Z up)
    crispin likes this.
  3. seanenroute
    I'll try that. Any ideas on how I should wire it for power? I have a bunch of small 12 volt solenoids I'll use.
  4. David the swarfer
    you will need a relay or MOSFET. the pin turns the relay on and off, and the relay switches the 12v for the solenoid.
    do not omit a snubber diode! keep the 12v wires away from the signal wires to the arduino.
    crispin likes this.
  5. seanenroute
    Excellent, thank you
