Tear down of Cubify cube 3 3D Printer + convert to RepRap
Discussion in '3D printers' started by Oderbang, Dec 6, 2015.
  1. eychei
    eychei Well-Known
    @Geezer70
    Thx for the compliment. Im trying my best to get this going. But this is teamwork, I need help here.
    P.S. I just zeroed my Cartridge:(
  2. Geezer70
    Geezer70 New
    @"eychei, Im trying my best to get this going. But this is teamwork, I need help here.
    P.S. I just zeroed my Cartridge:([/QUOTE]
    Just ask.... What do you need?
  3. Tom Dirriwachter
    Tom Dirriwachter Well-Known
    Are there the memory locations for the data or is this just where they are declared?
  4. Tom Dirriwachter
  5. eychei
    eychei Well-Known
    I just zeroed out this whole code:)
  6. eychei
    eychei Well-Known
  7. Tom Dirriwachter
    That would be V1.07, I guess.
    But it does have an Engineering mode... that is interesting.
  8. Tom Dirriwachter
  9. eychei
    eychei Well-Known
    yes that true. Should I flash 1.07...
    I do have so many things to try. I am on 1.14 right now. If someone fins something in IDA , i can try it.
    My cartridge is at 0% right now. I need to find the routine in which the cartridges is checked, read, and blocked if it is at 0%
  10. eychei
    eychei Well-Known
    I did write 00 as opcode (nop)
  11. Tom Dirriwachter
    Definitely stick to 1.14b.
    The 0 percent chip should be recoverable.
    Can you find the routine that checks the cartridge?
    You might be able to reroute and empty cartridge to the full cartridge routine.
    I think Geezer pointed to it in v1.10.
    If a cartridge is considered full, the FW may just ignore the current remaining value and replace it with whatever the current print requires. If this works as I suspect it does, empty chips will be "refilled".
    Also be aware that new cartridge installs can send the printer into the calibration routine that is difficult to get out of.
  12. Naldarn
    Naldarn New
    Looking into the config bits, which are the penultimate line in the hex file with debug off:
    :102FF000FFFFFF3CD979F8FF5B0DEDFFF7FFFF7F87
    And ON with checksum updated:
    :102FF000FFFFFF3CD979F8FF5B0DEDFFF7FFFF6F97
    Have I git this right, or am I shooting blind?
  13. eychei
    eychei Well-Known
    Actually debuging is working with the code you posted before.
  14. Naldarn
    Naldarn New
    Ok, so I just turned on code protect.
  15. eychei
    eychei Well-Known
  16. eychei
    eychei Well-Known
    Ok some update for you all.
    This is the write routine when you start a print. I did succeed in stopping the wri[ing process. But cartridge removed error is popping up after 30 seconds.
    #466 eychei, Jan 15, 2017
  17. Tom Dirriwachter
    There is likely a confirm step that it has written successfully.
  18. eychei
    eychei Well-Known
    Here is a goody for all of you.
    Kiza likes this.
  19. Tom Dirriwachter
  20. eychei
    eychei Well-Known
    Testing right now, it is working on both cartridge sites.
    Naldarn likes this.
  21. Tom Dirriwachter
    What is the idea behind your mod?
  22. Geezer70
    Geezer70 New
    BLAHH to Spiderman, You're my new Hero! CheCheMan. High-fives:duh::duh::duh:
    Joseph Chen likes this.
  23. eychei
    eychei Well-Known
    @Tom Dirriwachter
    Sorry. What do you mean?
    I did modify the firmware so it does not write the Cartridges. So it will stay at the percentage it is on.
    You can feed your own filament now without worrying about the chip itself.
    @Geezer70
    High Five Accepted:)
  24. eychei
    eychei Well-Known
    P.S:
    This patch is also working on the Cubepro V2.00 Firmware. I will be testing with some of my Beta Testers.
    Release will be end of this week for both printers if everything works like it should.
    Will release for both the Cube 3 and the Cubepro.
  25. eychei
    eychei Well-Known
    Willing to accept donations;)
  26. Tom Dirriwachter
    Did you figure out why it was resetting at 30 seconds?
    GoFundMe eychei :)
  27. fred_dot_u
    I'm new to this thread, having followed a link posted on another forum. As a (too) long time owner of a Cube3, I'm encouraged by what I've read thus far, all 17 pages of posts. The topic heading refers to the phrase "convert to reprap." Does this mean disassembly of the housing and replacement of components, or, as I am hoping, a firmware modification?
    If the latter, and eychei is able to provide for novice "hackers" such as myself, I'll certainly contribute to his funding.
  28. eychei
    eychei Well-Known
    Yes i did find a routine in which it was reading the cartridge and then going to the write process. The read routine did have some jumps and calls so i patched what i could find.
    But now i am down to 2 patches.
  29. eychei
    eychei Well-Known
    I will start a new thread when releasing the firmware. We hijacked this thread.
  30. Tom Dirriwachter
    Congrats! Way cool!
    ...And you are on 1.14B for the cube 3, right?
