Custom probe offset on Interface?
Discussion in 'Interfaces' started by UltiBots, Sep 23, 2024.
  1. UltiBots
    UltiBots Well-Known
    Hi All -
    I use my Interface often and WISH that I could use my own Probe. I tried to edit the probe files on flash drive by removing the <offset> parameter. Threw an error. Then I replaced offset with a 0, "<0>"... still an error.
    I saw this note:
    4.2 OpenBuilds Interface: Usage Instructions: Probing
    Note: At this time Interface only supports the OpenBuilds XYZ Probe Plus
    Please say this is old and there is a work around.
    TIA - Brad
    Docs are still valid. Grab one from our store and it will all work :)
  3. UltiBots
    UltiBots Well-Known
    Bummer... I have one but prefer to use a my Drewsonics s5000LED probe.
    Too bad the Interface is closed source. Having probe control without a PC tethered to the CNC would be AWESOME!!!
  4. David the swarfer
    There is, upgrade your wetware with actual Gcode knowledge (-:
    The <offset> in the file is a variable and not part of standard Gcode. The Interface is replacing that text with the number that is defined for the offset, thus creating valid Gcode.
    So instead of putting <0>, put the actual number offset your probe needs.
    probing with Gcode
    G Codes
    sttting 0 after the probe
    G Codes
    <offset> = probe + endmill radius so hardcoding an offset - one has to use same bit/dowel for probing then as endmill diameter menu was part of calculation.
  6. UltiBots
    UltiBots Well-Known
    Thanks Gents... I was so close! I overcomplicated this. G10 P0 L20 X-1.5875 = half of the 1/8" Ruby probe tip.
    So simple...
