Problem with post controller and Fusion 360
Discussion in 'General Talk' started by Craig H, Aug 16, 2023.
  1. Craig H
    Craig H New
    I need help! I am new to CNC. I recently finished a CNC plasma cutting table build. The control board is the Arduino Uno R3 flashed with GRBL. The table is a three-axis with z being a touch-off. There is no torch height control. I designed a simple 2" x 4" plate with 4 .325 in. holes in Fusion 360. I am using Openbuilds CNC: GRBL/Black box post controller. The person that helped me said I had to edit the Post controller to get the Z axis to touch off and retract between cuts. These are the edits he told me to make. At position 250 change plasma probe distance from 30 to 150. At position 252 change plasma probe rate from 100 to 150. Then he had me comment out lines 821, 822, 823, 824 with( 2 //). After that, the Z axis would function with touch-off and retract. When I went through all the steps in Fusion 360 and went to post it came up with NC code failed to post. The error was: The top height must be below the plasma pierce height: Error at line 842. I have tried everything, he had me uninstall Fusion 360 and reinstall. Then uninstall Openbuilds post controller and reinstall it. No change still get errors. I have the torch top height set at 0.045. I don't know where in Fusion 360 the pierce height even is. Any help would be greatly appreciated! Thank you, Craig
  2. David the swarfer
    Which version of the post have you got? latest is v1.0.0.36 and I will be using that for any explanations.
    Why would you reinstall when all you need to do is change some heights in your cut parameters in Fusion360?
    I am not near Fusion now, maybe I will post some screenshots later that show it, if the videos below don't help you out.
    Here GitHub - OpenBuilds/OpenBuilds-Fusion360-Postprocessor: Post Processor for Fusion 360 for use with OpenBuilds Machines running Grbl 1.1 you get some intructions for plasma touch off linked here
    OpenBuilds-Fusion360-Postprocessor/README-plasma.md at master · OpenBuilds/OpenBuilds-Fusion360-Postprocessor
    Why remove the retract code? Is it becuase your machine has no homing switches?
    The correct solution is to fake the home , it will provide a safer environment for you and your equipment.
    anyhow, back to adjusting heights.....
    short version
    long version
  3. David the swarfer
    you are looking for the linking tab for the pierce height, this sets how high the tool will be during piercing
    set the stock top to the same as the model top (no stock offsets), then set the cut height like this with a positive offset.
    this sets how high the tool will be during cutting
    you can override the pierce height in the post options because for some cuts the pierce height settings also affects the linking moves.
    if you hover your mouse over each of the option edit boxes in turn they will pop up some help
  4. Craig H
    Craig H New
    Thank you very much. Like I said I am very new to CNC. Those settings I gave you came from the guy I bought the plans from. I did finally get it to post. Now my issues are it touches off and goes up, but the torch tip is right down on the stock scraping. Thanks,Craig
  5. Craig H
    Craig H New
    Yes my machine has no homing switches or limit switches. There is only a switch on the Z axis. I will send you a pic of the setup.
  6. David the swarfer
    then please follow the link I gave you to the 'fake the home' instructions and do it everytime you turn the machine on, that will solve your scraping problem and also make the whole thing safer to operate
  7. Craig H
    Craig H New
    Hi, I have fixed most of the problems I was having. Now I have some new ones. I designed a simple 2-inch by 3-inch plate with 5 holes. The holes cut but they are not perfectly round. I measured the dimensions of the plate after cutting it. It measured 2 and 15/16 by 1 and 15/16. Thanks, Craig
    1) check mechanicals (setscrews on shaft couplers tight, wheels adjusted, machine as solid as can be)
    2) then check Calibration (Wizards and Tools menu)
  9. Craig H
    Craig H New
    I checked the mechanicals, they were all good. I went through the X and Y calibration in the wizard. They were both 100mm travel exactly. I have attached my set ups and my post-processing settings. I tried another 2-inch x 2-inch square. It cut both sides 1 15/16's.
  10. David the swarfer
    next to check is the 'cutter size'. ie the actual size of the kerf that is being cut and set that in the tool setup in Fusion.
    it uses the kerf width to set the offset when it generates the Gcode.
    Holes still oblong?
  12. Craig H
    Craig H New
    This is a small plate I cut with 7 holes. It is 14 ga galvanized.
    Plasma? Replace tip and electrode (worn tips often reason for cut artifacts)
    Also double check your kerf is configured correctly
  14. Louis Gagnon
    Hello
    I Have a similar problème
    When i do the set zéro after probing de z-axe that have a limites switch.
    Then i start the job for the first holl it go's à the good height after the sencond holl it go's up and after that up again en up and up and block it dosent do the probing for each cut that it suppos to do
    What could be the problème ? I follow the step up in this post but still not working
    And get this alarme
    Where is the Gcode
    (Made in : Autodesk CAM Post Processor)
    (G-Code optimized for Grbl 1.1 / BlackBox controller)
    (OpenBuilds CNC : GRBL/BlackBox)
    (Post-Processor : OpenbuildsFusion360PostGrbl.cps V1.0.36)
    (Units = mm)
    (Laser UseZ = false)
    (Laser UsePierce = false)
    (Arcs are limited to the XY plane: if you want vertical arcs then)
    (edit allowedCircularPlanes in the CPS file)
    (Drawing name : Rotary Axes v5)
    (Program Name : Full Rotation)
    (1 Operation :)
    (1 : 2D Profile3)
    ( Work Coordinate System : G54)
    ( Tool 1: Plasma Cutter Diam = 5mm)
    ( Machining time : 3 min 19 sec)
    G90 G94 G17
    G21
    (Plasma pierce height 1.5)
    (Plasma topHeight 0.5)
    (Operation 1 of 1 : 2D Profile3)
    G54
    (Plasma cutting with GRBL.)
    (Using torch height probe and pierce delay.)
    G0 X52.679 Y97.318 F1524
    G0 X52.679 Y97.318 Z15.24
    G38.2 Z-100 F150
    G10 L20 Z-2
    G0 Z1.5
    M3 S1000
    G4 P0.6
    G1 Z0.5 F1524
    G3 X54.203 Y95.794 I1.524 J0
    G1 X66.877 Y95.794
    G3 X68.401 Y97.318 I0 J1.524
    M5
    G0 X68.401 Y100.341
    X55.754 Y105.379
    G38.2 Z-100 F150
    G10 L20 Z-2
    G0 Z1.5
    M3
    G4 P0.6
    G1 Z0.5 F1524
    G1 X55.196 Y105.238
    G3 X55.649 Y103.131 I1.28 J-0.827
    X59.081 Y108.443 I1.716 J2.656
    X55.649 Y103.131 I-1.716 J-2.656
    X57.756 Y103.584 I0.827 J1.28
    M5
    G0 X56.072 Y146.018
    G38.2 Z-100 F150
    G10 L20 Z-2
    G0 Z1.5
    M3
    G4 P0.6
    G1 Z0.5 F1524
    G1 X55.624 Y145.657
    G3 X56.916 Y143.932 I1.509 J-0.216
    X57.814 Y150.192 I0.449 J3.13
    X56.916 Y143.932 I-0.449 J-3.13
    X58.641 Y145.224 I0.216 J1.509
    M5
    G0 X61.904 Y140.525
    X62.16 Y140.71
    X62.963 Y141.406
    X63.667 Y142.202
    X64.259 Y143.085
    X64.727 Y144.039
    X65.064 Y145.047
    X65.264 Y146.091
    X65.323 Y147.152
    X65.24 Y148.212
    X65.016 Y149.251
    X64.656 Y150.251
    X64.167 Y151.194
    X63.555 Y152.064
    X62.834 Y152.844
    X62.014 Y153.521
    X61.112 Y154.083
    X52.666 Y158.605
    G38.2 Z-100 F150
    G10 L20 Z-2
    G0 Z1.5
    M3
    G4 P0.6
    G1 Z0.5 F1524
    G3 X54.19 Y157.081 I1.524 J0
    G1 X66.877 Y157.081
    G3 X68.401 Y158.605 I0 J1.524
    M5
    G0 Z5.08
    X50.964 Y98.54
    G38.2 Z-100 F150
    G10 L20 Z-2
    G0 Z1.5
    M3
    G4 P0.6
    G1 Z0.5 F1524
    G3 X49.44 Y97.016 I0 J-1.524
    G1 X49.44 Y95.817
    G3 X50.924 Y92.234 I5.067 J0
    G1 X63.341 Y79.817
    G3 X66.924 Y78.333 I3.583 J3.583
    G1 X71.64 Y78.333
    X71.64 Y174.515
    X66.924 Y174.515
    G3 X63.341 Y173.031 I0 J-5.067
    G1 X50.924 Y160.615
    G3 X49.44 Y157.032 I3.583 J-3.583
    G1 X49.44 Y147.062
    G3 X53.241 Y140.295 I7.925 J0
    G1 X53.242 Y140.294
    G2 X53.275 Y112.575 I-10.704 J-13.873
    G1 X53.274 Y112.574
    G3 X49.44 Y105.787 I4.091 J-6.787
    G1 X49.44 Y97.016
    G3 X50.964 Y95.492 I1.524 J0
    M5
    G0 Z5.08
    X51.626 Y121.88
    G38.2 Z-100 F150
    G10 L20 Z-2
    G0 Z1.5
    M3
    G4 P0.6
    G1 Z0.5 F1524
    G3 X49.76 Y122.958 I-1.472 J-0.394
    G1 X37.505 Y119.674
    G3 X36.427 Y117.807 I0.394 J-1.472
    M5
    G0 X37.21 Y114.887
    X36.963 Y114.908
    X36.122 Y115.081
    X35.326 Y115.401
    X34.599 Y115.858
    X33.965 Y116.438
    X33.445 Y117.121
    X33.055 Y117.885
    X32.807 Y118.707
    X32.71 Y119.56
    X32.767 Y120.417
    X32.975 Y121.25
    X33.329 Y122.032
    X33.816 Y122.739
    X34.422 Y123.348
    X43.16 Y130.441
    G38.2 Z-100 F150
    G10 L20 Z-2
    G0 Z1.5
    M3
    G4 P0.6
    G1 Z0.5 F1524
    G1 X42.835 Y129.967
    G3 X44.568 Y128.685 I1.507 J0.226
    X43.632 Y134.941 I-0.468 J3.128
    X44.568 Y128.685 I0.468 J-3.128
    X45.85 Y130.418 I-0.226 J1.507
    M5
    G0 X32.559 Y170.258
    G38.2 Z-100 F150
    G10 L20 Z-2
    G0 Z1.5
    M3
    G4 P0.6
    G1 Z0.5 F1524
    G1 X32.263 Y169.765
    G3 X34.068 Y168.587 I1.491 J0.314
    X32.766 Y174.776 I-0.651 J3.094
    X34.068 Y168.587 I0.651 J-3.094
    X35.245 Y170.392 I-0.314 J1.491
    M5
    G0 X39.921 Y167.096
    X40.097 Y167.357
    X40.594 Y168.244
    X40.973 Y169.186
    X41.23 Y170.169
    X41.359 Y171.176
    X41.358 Y172.192
    X41.229 Y173.199
    X40.972 Y174.182
    X40.591 Y175.124
    X40.095 Y176.01
    X39.489 Y176.825
    X35.752 Y181.075
    G38.2 Z-100 F150
    G10 L20 Z-2
    G0 Z1.5
    M3
    G4 P0.6
    G1 Z0.5 F1524
    G3 X33.885 Y182.153 I-1.472 J-0.395
    G1 X21.642 Y178.872
    G3 X20.565 Y177.005 I0.395 J-1.472
    M5
    G0 Z5.08
    X45.59 Y103.046
    G38.2 Z-100 F150
    G10 L20 Z-2
    G0 Z1.5
    M3
    G4 P0.6
    G1 Z0.5 F1524
    G3 X43.478 Y103.472 I-1.27 J-0.843
    G2 X41.979 Y102.796 I-2.817 J4.243
    G1 X37.411 Y101.572
    X37.402 Y101.573
    X37.396 Y101.581
    X12.495 Y194.511
    X12.497 Y194.52
    X12.504 Y194.526
    X17.072 Y195.75
    G2 X20.936 Y195.242 I1.319 J-4.919
    G1 X36.143 Y186.462
    G2 X38.516 Y183.369 I-2.547 J-4.411
    G1 X41.096 Y173.739
    G2 X39.144 Y166.168 I-7.679 J-2.058
    G3 X46.34 Y139.441 I13.936 J-10.58
    G2 X51.779 Y133.87 I-2.24 J-7.628
    G1 X54.36 Y124.24
    G2 X53.851 Y120.376 I-4.919 J-1.318
    G1 X45.071 Y105.169
    G2 X43.478 Y103.472 I-4.411 J2.546
    G3 X43.051 Y101.36 I0.843 J-1.27
    M5
    G0 X44.142 Y98.459
    X43.81 Y98.341
    X43.22 Y98.163
    X38.653 Y96.939
    X37.861 Y96.797
    X37.057 Y96.788
    X36.262 Y96.914
    X35.5 Y97.17
    X34.791 Y97.55
    X34.155 Y98.043
    X33.61 Y98.635
    X33.172 Y99.309
    X27.012 Y111.172
    G38.2 Z-100 F150
    G10 L20 Z-2
    G0 Z1.5
    M3
    G4 P0.6
    G1 Z0.5 F1524
    G3 X25.488 Y112.696 I-1.524 J0
    G1 X12.813 Y112.696
    G3 X11.289 Y111.172 I0 J-1.524
    M5
    G0 X11.289 Y108.149
    X23.144 Y101.256
    G38.2 Z-100 F150
    G10 L20 Z-2
    G0 Z1.5
    M3
    G4 P0.6
    G1 Z0.5 F1524
    G1 X23.427 Y100.756
    G3 X25.34 Y101.748 I0.46 J1.453
    X22.326 Y105.865 I-3.015 J0.955
    X22.326 Y99.541 I0 J-3.162
    X25.34 Y101.748 I0 J3.162
    X24.347 Y103.661 I-1.453 J0.46
    M5
    G0 X29.517 Y106.111
    X29.645 Y105.825
    X29.998 Y104.817
    X30.212 Y103.77
    X30.283 Y102.703
    X30.259 Y102.074
    X30.184 Y101.449
    X23.975 Y61.63
    G38.2 Z-100 F150
    G10 L20 Z-2
    G0 Z1.5
    M3
    G4 P0.6
    G1 Z0.5 F1524
    G1 X24.546 Y61.7
    G3 X24.362 Y63.847 I-1.166 J0.982
    X20.289 Y59.009 I-2.037 J-2.419
    X24.362 Y63.847 I2.037 J2.419
    X22.215 Y63.663 I-0.982 J-1.166
    M5
    G0 X21.932 Y69.377
    X22.326 Y69.387
    X23.397 Y69.314
    X24.449 Y69.098
    X25.462 Y68.742
    X26.418 Y68.254
    X27.3 Y67.64
    X28.091 Y66.914
    X28.777 Y66.088
    X29.346 Y65.177
    X29.786 Y64.198
    X30.091 Y63.168
    X30.255 Y62.107
    X30.274 Y61.033
    X30.148 Y59.967
    X29.88 Y58.927
    X27.024 Y49.886
    G38.2 Z-100 F150
    G10 L20 Z-2
    G0 Z1.5
    M3
    G4 P0.6
    G1 Z0.5 F1524
    G3 X25.5 Y51.41 I-1.524 J0
    G1 X12.813 Y51.41
    G3 X11.289 Y49.886 I0 J-1.524
    M5
    G0 X11.289 Y46.862
    X11.057 Y46.947
    X10.344 Y47.298
    X9.699 Y47.762
    X9.139 Y48.327
    X8.681 Y48.976
    X8.335 Y49.692
    X8.113 Y50.456
    X8.02 Y51.245
    X8.059 Y52.039
    X8.228 Y52.816
    X8.523 Y53.554
    X31.818 Y101.295
    G38.2 Z-100 F150
    G10 L20 Z-2
    G0 Z1.5
    M3
    G4 P0.6
    G1 Z0.5 F1524
    G3 X29.905 Y100.302 I-0.46 J-1.453
    G2 X26.43 Y95.895 I-7.579 J2.401
    G3 X26.464 Y68.217 I10.723 J-13.826
    G2 X30.276 Y61.428 I-4.138 J-6.788
    G1 X30.276 Y51.458
    G2 X28.784 Y47.857 I-5.093 J0
    G1 X16.367 Y35.441
    G2 X12.766 Y33.949 I-3.601 J3.601
    G1 X8.038 Y33.949
    X8.029 Y33.953
    X8.025 Y33.962
    X8.025 Y130.17
    X8.029 Y130.179
    X8.038 Y130.183
    X12.766 Y130.183
    G2 X16.367 Y128.691 I0 J-5.093
    G1 X28.784 Y116.274
    G2 X30.276 Y112.673 I-3.601 J-3.601
    G1 X30.276 Y102.703
    G2 X29.905 Y100.302 I-7.95 J0
    G3 X30.897 Y98.389 I1.453 J-0.46
    M5
    G0 X34.427 Y97.271
    X35.065 Y61.832
    X35.072 Y61.428
    X35.072 Y51.458
    X35.015 Y50.401
    X34.846 Y49.356
    X34.566 Y48.336
    X34.178 Y47.35
    X19.556 Y16.577
    G38.2 Z-100 F150
    G10 L20 Z-2
    G0 Z1.5
    M3
    G4 P0.6
    G1 Z0.5 F1524
    G1 X20.077 Y16.82
    G3 X19.238 Y18.805 I-1.412 J0.573
    X16.86 Y12.945 I-1.189 J-2.93
    X19.238 Y18.805 I1.189 J2.93
    X17.253 Y17.966 I-0.573 J-1.412
    M5
    G0 X15.217 Y23.313
    X15.512 Y23.418
    X16.435 Y23.668
    X17.382 Y23.805
    X18.338 Y23.828
    X19.29 Y23.736
    X20.224 Y23.53
    X44.675 Y16.997
    G38.2 Z-100 F150
    G10 L20 Z-2
    G0 Z1.5
    M3
    G4 P0.6
    G1 Z0.5 F1524
    G1 X45.1 Y17.385
    G3 X43.703 Y19.027 I-1.519 J0.123
    X43.194 Y12.723 I-0.255 J-3.152
    X43.703 Y19.027 I0.255 J3.152
    X42.062 Y17.631 I-0.123 J-1.519
    M5
    G0 X38.515 Y22.119
    X73.572 Y48.819
    G38.2 Z-100 F150
    G10 L20 Z-2
    G0 Z1.5
    M3
    G4 P0.6
    G1 Z0.5 F1524
    G3 X72.048 Y47.295 I0 J-1.524
    G1 X72.048 Y11.125
    G3 X73.572 Y9.601 I1.524 J0
    M5
    G0 X76.595 Y9.601
    X102.092 Y48.819
    G38.2 Z-100 F150
    G10 L20 Z-2
    G0 Z1.5
    M3
    G4 P0.6
    G1 Z0.5 F1524
    G3 X100.568 Y47.295 I0 J-1.524
    G1 X100.568 Y11.125
    G3 X102.092 Y9.601 I1.524 J0
    M5
    G0 X105.115 Y9.601
    X129.068 Y17.536
    G38.2 Z-100 F150
    G10 L20 Z-2
    G0 Z1.5
    M3
    G4 P0.6
    G1 Z0.5 F1524
    G1 X129.043 Y18.11
    G3 X126.887 Y18.093 I-1.069 J-1.086
    X131.395 Y13.657 I2.254 J-2.218
    X126.887 Y18.093 I-2.254 J2.218
    X126.904 Y15.938 I1.086 J-1.069
    M5
    G0 X121.186 Y16.1
    X121.201 Y16.417
    X121.345 Y17.473
    X121.628 Y18.501
    X122.046 Y19.481
    X122.592 Y20.396
    X123.255 Y21.231
    X124.023 Y21.969
    X124.883 Y22.599
    X125.82 Y23.107
    X126.816 Y23.486
    X127.854 Y23.728
    X128.914 Y23.83
    X129.979 Y23.789
    X131.029 Y23.606
    X154.242 Y17.51
    G38.2 Z-100 F150
    G10 L20 Z-2
    G0 Z1.5
    M3
    G4 P0.6
    G1 Z0.5 F1524
    G1 X154.139 Y18.076
    G3 X152.006 Y17.765 I-0.911 J-1.222
    X157.076 Y13.985 I2.535 J-1.89
    X152.006 Y17.765 I-2.535 J1.89
    X152.317 Y15.633 I1.222 J-0.911
    M5
    G0 X146.629 Y15.013
    X111.825 Y194.564
    G38.2 Z-100 F150
    G10 L20 Z-2
    G0 Z1.5
    M3
    G4 P0.6
    G1 Z0.5 F1524
    G1 X111.655 Y194.295
    G3 X112.124 Y192.192 I1.286 J-0.817
    X117.558 Y200.746 I2.717 J4.277
    X112.124 Y192.192 I-2.717 J-4.277
    X114.228 Y192.661 I0.817 J1.286
    M5
    G0 X113.272 Y186.731
    X99.018 Y186.69
    G38.2 Z-100 F150
    G10 L20 Z-2
    G0 Z1.5
    M3
    G4 P0.6
    G1 Z0.5 F1524
    G3 X100.542 Y188.214 I0 J1.524
    G1 X100.542 Y204.775
    G3 X99.018 Y206.299 I-1.524 J0
    M5
    G0 X95.995 Y206.299
    X70.498 Y186.69
    G38.2 Z-100 F150
    G10 L20 Z-2
    G0 Z1.5
    M3
    G4 P0.6
    G1 Z0.5 F1524
    G3 X72.022 Y188.214 I0 J1.524
    G1 X72.022 Y204.775
    G3 X70.498 Y206.299 I-1.524 J0
    M5
    G0 X67.475 Y206.299
    X55.979 Y193.372
    G38.2 Z-100 F150
    G10 L20 Z-2
    G0 Z1.5
    M3
    G4 P0.6
    G1 Z0.5 F1524
    G1 X55.954 Y193.055
    G3 X57.355 Y191.417 I1.519 J-0.118
    X58.143 Y201.521 I0.394 J5.052
    X57.355 Y191.417 I-0.394 J-5.052
    X58.993 Y192.818 I0.118 J1.519
    M5
    G0 Z5.08
    X72.566 Y75.756
    G38.2 Z-100 F150
    G10 L20 Z-2
    G0 Z1.5
    M3
    G4 P0.6
    G1 Z0.5 F1524
    G3 X74.09 Y77.28 I0 J1.524
    G1 X74.09 Y181.61
    X74.094 Y181.619
    X74.103 Y181.623
    G3 X74.103 Y183.426 I0 J0.902
    G1 X55.626 Y183.426
    G2 X53.821 Y184.174 I0 J2.553
    G1 X48.959 Y189.036
    G2 X48.211 Y190.841 I1.805 J1.805
    G1 X48.211 Y202.148
    G2 X48.959 Y203.953 I2.553 J0
    G1 X53.821 Y208.815
    G2 X55.626 Y209.563 I1.805 J-1.805
    G1 X116.964 Y209.563
    G2 X118.769 Y208.815 I0 J-2.553
    G1 X123.631 Y203.953
    G2 X124.379 Y202.148 I-1.805 J-1.805
    G1 X124.379 Y190.841
    G2 X123.631 Y189.036 I-2.553 J0
    G1 X118.769 Y184.174
    G2 X116.964 Y183.426 I-1.805 J1.805
    G1 X98.487 Y183.426
    G3 X98.487 Y181.623 I0 J-0.902
    G1 X98.496 Y181.619
    X98.5 Y181.61
    X98.5 Y53.899
    X98.496 Y53.89
    X98.487 Y53.886
    G3 X98.487 Y52.083 I0 J-0.902
    G1 X117.629 Y52.083
    G2 X118.953 Y51.712 I-0.001 J-2.553
    G1 X163.791 Y24.507
    G2 X165.019 Y22.324 I-1.325 J-2.182
    G1 X165.019 Y8.89
    G2 X162.466 Y6.337 I-2.553 J0
    G1 X10.124 Y6.337
    G2 X7.571 Y8.89 I0 J2.553
    G1 X7.571 Y22.324
    G2 X8.8 Y24.507 I2.553 J0
    G1 X53.637 Y51.712
    G2 X54.961 Y52.083 I1.324 J-2.182
    G1 X74.103 Y52.083
    G3 X74.103 Y53.886 I0 J0.902
    G1 X74.094 Y53.89
    X74.09 Y53.899
    X74.09 Y77.28
    G3 X72.566 Y78.804 I-1.524 J0
    M5
    G0 Z5.08
    X28.008 Y207.55
    G38.2 Z-100 F150
    G10 L20 Z-2
    G0 Z1.5
    M3
    G4 P0.6
    G1 Z0.5 F1524
    G3 X26.208 Y208.736 I-1.493 J-0.306
    G2 X25.445 Y208.658 I-0.769 J3.745
    G1 X14.015 Y208.64
    G2 X10.187 Y212.457 I-0.006 J3.823
    X14.004 Y216.286 I3.823 J0.006
    G1 X25.434 Y216.304
    G2 X26.208 Y208.736 I0.006 J-3.823
    G3 X25.022 Y206.937 I0.306 J-1.493
    M5
    G0 X25.653 Y203.865
    X25.975 Y203.879
    X27.08 Y204.02
    X28.159 Y204.302
    X29.191 Y204.722
    X30.161 Y205.271
    X31.052 Y205.94
    X31.849 Y206.719
    X32.539 Y207.594
    X43.074 Y222.646
    G38.2 Z-100 F150
    G10 L20 Z-2
    G0 Z1.5
    M3
    G4 P0.6
    G1 Z0.5 F1524
    G3 X41.548 Y224.167 I-1.524 J-0.002
    G1 X11.147 Y224.121
    G3 X9.625 Y222.595 I0.002 J-1.524
    M5
    G0 X7.761 Y220.725
    X7.59 Y220.904
    X7.101 Y221.546
    X6.727 Y222.261
    X6.477 Y223.028
    X6.36 Y223.827
    X6.378 Y224.634
    X6.532 Y225.426
    X6.816 Y226.181
    X7.223 Y226.878
    X7.741 Y227.497
    X8.355 Y228.021
    X9.048 Y228.434
    X9.801 Y228.725
    X51.06 Y240.771
    G38.2 Z-100 F150
    G10 L20 Z-2
    G0 Z1.5
    M3
    G4 P0.6
    G1 Z0.5 F1524
    G3 X49.533 Y242.292 I-1.524 J-0.002
    G1 X31.063 Y242.264
    G2 X29.517 Y246.851 I-0.004 J2.553
    G1 X67.619 Y275.735
    G2 X71.714 Y273.705 I1.542 J-2.034
    G1 X71.758 Y244.879
    G2 X69.209 Y242.322 I-2.553 J-0.004
    G1 X49.533 Y242.292
    G3 X48.012 Y240.766 I0.002 J-1.524
    M5
    G0 X48.017 Y237.063
    X48.21 Y236.913
    X48.809 Y236.536
    X49.457 Y236.25
    X50.14 Y236.064
    X50.843 Y235.98
    X51.551 Y236
    X69.827 Y237.553
    X70.635 Y237.667
    X71.424 Y237.869
    X72.186 Y238.158
    X85.094 Y243.944
    G38.2 Z-100 F150
    G10 L20 Z-2
    G0 Z1.5
    M3
    G4 P0.6
    G1 Z0.5 F1524
    G1 X84.322 Y243.682
    G3 X85.445 Y241.843 I1.481 J-0.358
    X86.613 Y246.679 I0.584 J2.418
    X85.445 Y241.843 I-0.584 J-2.418
    X87.284 Y242.967 I0.358 J1.481
    M5
    G0 X91.1 Y239.033
    X91.312 Y239.247
    X91.513 Y239.468
    X102.389 Y251.817
    G38.2 Z-100 F150
    G10 L20 Z-2
    G0 Z1.5
    M3
    G4 P0.6
    G1 Z0.5 F1524
    G1 X102.375 Y251.777
    G3 X103.321 Y249.84 I1.441 J-0.495
    X115.665 Y285.752 I6.172 J17.956
    X103.321 Y249.84 I-6.172 J-17.956
    X105.257 Y250.786 I0.495 J1.441
    M5
    G0 X103.746 Y244.717
    X103.245 Y244.848
    X101.445 Y245.416
    X99.695 Y246.125
    X98.007 Y246.97
    X96.392 Y247.947
    X94.858 Y249.048
    X93.418 Y250.268
    X92.078 Y251.598
    X90.848 Y253.03
    X89.736 Y254.556
    X88.748 Y256.164
    X87.891 Y257.846
    X87.17 Y259.591
    X86.589 Y261.388
    X86.153 Y263.224
    X85.864 Y265.09
    X85.724 Y266.973
    X85.041 Y290.893
    G38.2 Z-100 F150
    G10 L20 Z-2
    G0 Z1.5
    M3
    G4 P0.6
    G1 Z0.5 F1524
    G1 X84.285 Y290.588
    G3 X85.508 Y288.814 I1.499 J-0.275
    X86.406 Y293.707 I0.449 J2.447
    X85.508 Y288.814 I-0.449 J-2.447
    X87.283 Y290.038 I0.275 J1.499
    M5
    G0 X91.31 Y286.322
    X100.906 Y289.975
    X102.672 Y290.58
    X104.479 Y291.045
    X106.317 Y291.366
    X108.175 Y291.543
    X110.041 Y291.573
    X131.983 Y291.17
    G38.2 Z-100 F150
    G10 L20 Z-2
    G0 Z1.5
    M3
    G4 P0.6
    G1 Z0.5 F1524
    G1 X131.178 Y291.037
    G3 X131.99 Y289.04 I1.404 J-0.592
    X133.923 Y293.624 I0.966 J2.292
    X131.99 Y289.04 I-0.966 J-2.292
    X133.987 Y289.852 I0.592 J1.404
    M5
    G0 X137.118 Y285.354
    X152.475 Y237.035
    G38.2 Z-100 F150
    G10 L20 Z-2
    G0 Z1.5
    M3
    G4 P0.6
    G1 Z0.5 F1524
    G3 X152.108 Y239.158 I-1.245 J0.878
    G2 X151.026 Y241.24 I1.471 J2.086
    G1 X150.998 Y259.3
    G2 X155.418 Y261.034 I2.553 J-0.007
    G1 X178.879 Y235.875
    G2 X176.271 Y231.691 I-1.866 J-1.741
    G1 X152.837 Y238.802
    G2 X152.108 Y239.158 I0.741 J2.442
    G3 X149.984 Y238.791 I-0.878 J-1.245
    M5
    G0 X147.85 Y235.765
    X147.487 Y225.582
    G38.2 Z-100 F150
    G10 L20 Z-2
    G0 Z1.5
    M3
    G4 P0.6
    G1 Z0.5 F1524
    G3 X148.633 Y223.757 I1.486 J-0.34
    G1 X159.332 Y221.309
    G3 X163.121 Y223.691 I0.705 J3.083
    X160.733 Y227.477 I-3.084 J0.701
    G1 X148.76 Y230.178
    X148.76 Y230.178
    X148.759 Y230.178
    X148.759 Y230.178
    G3 X144.592 Y228.003 I-1.104 J-2.964
    X147.19 Y224.087 I3.062 J-0.789
    G1 X147.191 Y224.086
    X148.633 Y223.757
    G3 X150.458 Y224.902 I0.34 J1.486
    M5
    G0 X149.049 Y218.741
    X145.95 Y219.441
    X144.886 Y219.753
    X143.876 Y220.211
    X142.939 Y220.804
    X142.094 Y221.521
    X141.357 Y222.35
    X140.741 Y223.272
    X140.261 Y224.272
    X132.043 Y244.275
    G38.2 Z-100 F150
    G10 L20 Z-2
    G0 Z1.5
    M3
    G4 P0.6
    G1 Z0.5 F1524
    G1 X131.229 Y244.228
    G3 X131.823 Y242.156 I1.333 J-0.738
    X134.234 Y246.508 I1.205 J2.176
    X131.823 Y242.156 I-1.205 J-2.176
    X133.895 Y242.751 I0.738 J1.333
    M5
    G0 X136.528 Y237.944
    X140.004 Y225.022
    X140.36 Y224.034
    X140.842 Y223.102
    X141.442 Y222.241
    X142.151 Y221.467
    X142.955 Y220.792
    X143.841 Y220.229
    X144.794 Y219.788
    X145.796 Y219.476
    X158.262 Y216.634
    X159.302 Y216.468
    X160.354 Y216.44
    X197.128 Y217.23
    G38.2 Z-100 F150
    G10 L20 Z-2
    G0 Z1.5
    M3
    G4 P0.6
    G1 Z0.5 F1524
    G1 X196.554 Y217.264
    G3 X196.35 Y215.119 I0.971 J-1.175
    X201.226 Y219.147 I2.438 J2.014
    X196.35 Y215.119 I-2.438 J-2.014
    X198.495 Y214.914 I1.175 J0.971
    M5
    G0 X197.747 Y209.242
    X201.733 Y202.163
    G38.2 Z-100 F150
    G10 L20 Z-2
    G0 Z1.5
    M3
    G4 P0.6
    G1 Z0.5 F1524
    G3 X200.588 Y203.989 I-1.486 J0.34
    G1 X182.08 Y208.228
    G3 X180.254 Y207.082 I-0.34 J-1.486
    M5
    G0 X179.579 Y204.135
    X196.651 Y179.974
    G38.2 Z-100 F150
    G10 L20 Z-2
    G0 Z1.5
    M3
    G4 P0.6
    G1 Z0.5 F1524
    G3 X195.506 Y181.8 I-1.486 J0.34
    G1 X176.998 Y186.039
    G3 X175.172 Y184.893 I-0.34 J-1.486
    M5
    G0 X174.497 Y181.946
    X186.202 Y169.624
    G38.2 Z-100 F150
    G10 L20 Z-2
    G0 Z1.5
    M3
    G4 P0.6
    G1 Z0.5 F1524
    G1 X185.645 Y169.767
    G3 X185.036 Y167.7 I0.729 J-1.338
    X190.59 Y170.725 I2.777 J1.513
    X185.036 Y167.7 I-2.777 J-1.513
    X187.103 Y167.09 I1.338 J0.729
    M5
    G0 X185.288 Y161.665
    X185.585 Y161.572
    X186.668 Y161.337
    X187.774 Y161.254
    X188.88 Y161.326
    X189.966 Y161.551
    X191.01 Y161.924
    X191.992 Y162.439
    X192.893 Y163.086
    X193.695 Y163.851
    X194.383 Y164.721
    X194.943 Y165.678
    X200.984 Y177.918
    X201.182 Y178.401
    X201.326 Y178.903
    X201.465 Y179.799
    X201.474 Y180.706
    X201.353 Y181.605
    X201.104 Y182.477
    X200.733 Y183.305
    X200.248 Y184.071
    X199.658 Y184.76
    X198.975 Y185.357
    X198.214 Y185.85
    X197.391 Y186.23
    X119.35 Y213.96
    X118.768 Y214.134
    X70.142 Y226.079
    G38.2 Z-100 F150
    G10 L20 Z-2
    G0 Z1.5
    M3
    G4 P0.6
    G1 Z0.5 F1524
    G1 X69.687 Y225.726
    G3 X70.946 Y223.977 I1.504 J-0.245
    X71.964 Y230.219 I0.509 J3.121
    X70.946 Y223.977 I-0.509 J-3.121
    X72.695 Y225.236 I0.245 J1.504
    M5
    G0 X75.867 Y220.475
    X76.117 Y220.648
    X76.968 Y221.359
    X77.712 Y222.181
    X78.335 Y223.098
    X78.824 Y224.093
    X79.17 Y225.146
    X79.366 Y226.237
    X79.409 Y227.345
    X79.298 Y228.448
    X79.034 Y229.525
    X78.623 Y230.555
    X78.073 Y231.518
    X77.395 Y232.395
    X76.601 Y233.169
    X75.707 Y233.825
    X74.731 Y234.351
    X73.691 Y234.736
    X72.608 Y234.972
    X71.503 Y235.056
    X70.396 Y234.986
    X69.31 Y234.762
    X68.266 Y234.39
    X67.284 Y233.876
    X66.382 Y233.23
    X65.579 Y232.466
    X40.894 Y205.659
    G38.2 Z-100 F150
    G10 L20 Z-2
    G0 Z1.5
    M3
    G4 P0.6
    G1 Z0.5 F1524
    G3 X42.421 Y204.138 I1.524 J0.002
    G1 X43.813 Y204.14
    G3 X46.337 Y206.67 I-0.004 J2.527
    G1 X46.306 Y227.06
    G2 X49.506 Y227.078 I1.6 J0.003
    G1 X56.478 Y227.089
    G2 X64.903 Y222.639 I0.015 J-10.173
    G3 X79.267 Y225.769 I6.551 J4.459
    G2 X80.894 Y229.798 I10.029 J-1.706
    X138.228 Y229.859 I28.688 J-19.581
    X139.846 Y225.864 I-8.407 J-5.728
    G3 X145.886 Y219.489 I7.81 J1.351
    G1 X174.966 Y212.83
    G2 X178.081 Y212.103 I1.556 J-0.37
    G1 X166.988 Y163.665
    G3 X177.154 Y154.875 I7.415 J-1.698
    G1 X191.252 Y160.343
    G3 X196.786 Y166.056 I-3.44 J8.868
    G1 X208.24 Y216.069
    G3 X205.745 Y223.619 I-9.453 J1.063
    G1 X138.695 Y295.521
    G3 X136.843 Y296.325 I-1.848 J-1.723
    G1 X81.801 Y296.241
    G3 X80.278 Y295.728 I0.004 J-2.527
    G1 X7.363 Y240.453
    G3 X6.363 Y238.435 I1.527 J-2.014
    G1 X6.411 Y206.61
    G3 X8.942 Y204.086 I2.527 J0.003
    G1 X42.421 Y204.138
    G3 X43.942 Y205.664 I-0.002 J1.524
    M5
    G0 Z15.24
    M5
    G0 X0 Y0
    M30
    #14 Louis Gagnon, Nov 13, 2023
  15. David the swarfer
    this is (or was) common with GRBL controllers, they are little too sensitive to arc endpoint errors.
    and that tells me we have a solution for you. you have V1.0.36 and the current version is V1.0.37 which has significant improvements in it specially for preventing arc errors so please upgrade and regenerate your Gcode and test and let us know if you have further problems
    docs:software:fusion360 [OpenBuilds Documentation]
    However, I cannot see any actual error in the arc coordinates so I have to think of other possible causes and all I have come up with is a USB communication error caused by EMI.
    It is a plasma cutter after all and that line of code is where the arc has just burned through and has just moved closer to the material.
    Whether that causes any special EMI or not is hard to say, but it is possible, so if you can run it with the plasma off that might tell us more about what is going on.
    Maybe the probe switch wiring needs to be shielded and filtered if it is not already?[/quote][/QUOTE]
  16. Louis Gagnon
    Hello
    I did the update of the GRBL post-prossesor to V1.0.37 and a redid the job. But got the same error and this time de plasma cutter was off.
    the relais clicked so the plasmas could start(power off plasma is off) that for me is ok
    The wire hare all shielded Z-switche motors and i did instal a EMI on the power sorce of the control box. juste to try to eliminate the fréquence.
    here are my setting on Fusion360 im running out of ideas
    this is the 2D profile
    upload_2023-11-13_15-47-41.png upload_2023-11-13_15-48-2.png upload_2023-11-13_15-48-20.png
    this is the NC program
    And this is the New Gcode
    G-code.txt
    Thank you for your help
    #16 Louis Gagnon, Nov 13, 2023
  17. Louis Gagnon
    It seam's that it is not using the touch prob routine.
    it dosent confirme with the z axis switch at eatch cut that it has to do so it goes down a litle bit and after more up until it jams
    i did 2X 2Dprofilt to split the job in two so one does the small holes and the other the bigger outline cut.
    With this the alarm desaperd. but stil the z-axe goes up and up and up.
  18. David the swarfer
    it does use the probe routine, 42 times in fact.
    lets look at what the gcode is doing
    Code:
    G0 X52.679 Y97.318 Z15.24       ; go to initial position, 15mm high
    G38.2 Z-100 F150                      ; probe down till contact
    G10 L20 Z-2                               ; set Z offset
    G0 Z1.5                                      ; set Z to 1.5 high from the probed+offset position
    M3 S1000                                  ; torch on
    G4 P0.6                                     ;  penetrate delay
    G1 Z0.5 F1524                           ; reduce Z hegiht to 0.5mm
    G3 X54.203 Y95.794 I1.524 J0  ; perform lead-in arc, 1.524mm radius as specified in your parameters
    G1 X66.877 Y95.794                  ; straight cut
    G3 X68.401 Y97.318 I0 J1.524  ; lead out arc
    M5                                              ; torch off
    G0 X68.401 Y100.341                ; move to new position
    X55.754 Y105.379                      ; move to new position, in 2 parts because it is avoiding the existing cut
    G10 L20 Z-2                              ; set offset
    G0 Z1.5                                     ; raise a little
    M3                                             ; torch on
    G4 P0.6                                    ; delay
    G1 Z0.5 F1524                         ; lower
    G1 X55.196 Y105.238              ; start cut, about 0.5mm move
    G3 X55.649 Y103.131 I1.28 J-0.827  ; leadin arc
    X59.081 Y108.443 I1.716 J2.656       ; cut circle
    X55.649 Y103.131 I-1.716 J-2.656   ; cut circle
    X57.756 Y103.584 I0.827 J1.28      ; leadout arc
    M5                                                ; torch off
    G0 X56.072 Y146.018                     ; move to start of new cut
    and so on
    technically speaking there should be a retract after the torch off commands and I will check later as to why there is not. This may be causing a problem because the torch is only 0.5mm away from the plate when the probe starts, may be even less if the plate is not flat and happens to be a high spot .
    Please fake the home (if you do not do this already) and run it again, Z home should be at the top of travel.
    I also note that the G38 commands do not have P words and while the default is to change the current WCS if there is no P word, maybe they really are needed so I will add that to the postprocessor tonight
    #18 David the swarfer, Nov 14, 2023
  19. David the swarfer
    come to think of it, that is a very long staydown setting and that might be causing the lack of retracts between probes/cut starts.
    since it is probing down anyway having it retract to 5mm clearance will not slow down your job much.
    so turn off 'keep nozzle down' and/or set the maximum staydown distance to 20mm.
    then, your 'tolerance' and 'smoothing tolerance' are very very small. (0.0004mm)
    your machine probably cannot even do that as a single step so it is not helping you at all.
    my machines step size is 0.025mm so I set tolerance to that, and smoothing to 3 or 4 times that.
  20. Louis Gagnon
    The fake homing is when go to the start position of the job and then do the set zero ?
    If yes that is what a do at every time to start de job.
  21. Louis Gagnon
    I did the teste to remouve de keep nozzle down and it is stil not working.
    At the begenning of the job it dosent do the first toch off for the cut and after that it start cutting and the next cut not toching the plate to teste the probe.
    I dont now if this could help but it is a JD's garage plasma CNC.
    and sorry for my bad english
  22. Alex Chambers
    No, when you set XYZ zero (in the same place on your workpiece as you set the origin in your cam software) you are setting the Workplace Co-ordinate System (WCS) zero. That is recorded by the controller as an offset from the HOME position which is setting the Machine Co-ordinate System (MCS).
    MCS home (together with the max dimension settings for each axis) tells your controller where all the edges and corners of your machine's workspace are, WCS zero tells your controller whereabouts in that workspace you put the workpiece.
    You need to How to 'Fake the home' if you haven't got switches that allow you to set a homing position. Setting a home position (regardless of where you put any switches if you have them) sets the back, right, up corner of your machine's workspace as the maxima for each axis. Confusingly for beginners that is normally zero - the machine co-ordinates become more negative as you move away from that corner.
    #22 Alex Chambers, Nov 14, 2023
  23. Peter Van Der Walt
    Rather than Fake the home, just spend the couple bucks and get switches. No need to go through the pain of remembering to "fake it"
    Fake it till you make it (try it now, see how big a pain it is, then order couple Xtension Limit Switch Kit)
    I really wish we'd just stop recommending the faking and recommend switches. Do it right
  24. Louis Gagnon
    Hello event whit the fake homing it is still not working it
    I made some little video to show you
    You will see that when a start a job what the z-axe moves up and up
    The video should work now
    #24 Louis Gagnon, Nov 14, 2023
  25. Louis Gagnon
    The video sould work now
  26. David the swarfer
    I think I know the problem.
    You have connected the switch on Z that senses the contact to the *Z-limit switch input*.
    It must be connected to the 'probe' input.
  27. David the swarfer
    and sorry, did not get to look at the post last night, had to go and tow my daughter home, followed by a loadshedding power out so I went to sleep early.
  28. Louis Gagnon
    The problème is that the système is bilt on a arduino uno
  29. Peter Van Der Walt
    Same concept. Use the probe pin, not the Endstop pins.
    Arduino pinout here: Connecting Grbl
  30. Louis Gagnon
    Yes it is connecter to A5 and ground whit à 10k resistor
